Power Steering Fluid???
What kind should I use on my 00 Max? I'm having to replace my high pressure hose, and need to get some fluid. What kind is good while not spending a ton of money?
I have to top up my power steering fluid every 2 days or so , I have a major leak in my HP hose so I just gotta wait until the new one comes in.....so I just buy the cheap shelf brand for now
Sorry to revive this old thread but my question fits right in: I need to replace my PS fluid; it has never been replaced and the car has 133K miles. For simplicity, I would prefer to use the AT fluid in my PS as well. So, my first question is: Do I have to be extra careful to fully drain the old fluid before pouring in the ATF, so that the two don't mix?
My 2nd question is: If I decide to stick with the original fluid type, what fluid do I actually buy? The manual says "Genuine Nissan PSFII or equivalent"; what do I look for at Autozone/O'Reileys ?
Sorry to revive this old thread but my question fits right in: I need to replace my PS fluid; it has never been replaced and the car has 133K miles. For simplicity, I would prefer to use the AT fluid in my PS as well. So, my first question is: Do I have to be extra careful to fully drain the old fluid before pouring in the ATF, so that the two don't mix? My 2nd question is: If I decide to stick with the original fluid type, what fluid do I actually buy? The manual says "Genuine Nissan PSFII or equivalent"; what do I look for at Autozone/O'Reileys ?
Just use a cheap spray bottle and get all the old fluid out you can, then repeat every 100 miles give or take, until it's all cycled out.
http://forums.nicoclub.com/what-is-e...d-t524547.html
OK, by "cooler hose" you refer to the thin hose between the cooler and the PS reservoir, I assume. Whether I disconnect it at the reservoir or elsewhere, all the new fluid will run out from the reservoir .... somehow this does not make sense to me. What am I missing?
lowpost99
Oct 26, 2025 06:53 PM
