My motor mounts video..as the car is being driven.
Old Sep 12, 2011 | 11:33 AM
  #41
Aaron92SE's Avatar
NWP Engineering.com
Originally Posted by geenowalker
Thanks...before I burn 500 on mounts, is there a way to tell which ones are history, or should I buy them all. I am not capable (time) of replacing mysefl.
thx
It is really hard to inspect them while they are installed on the crossmember since the rubber is covered by a metal plate. To inspect them properly, you'll need to support the engine with a scissor jack and block of wood and remove the crossmember with the 2 mounts. Then you'll easily see if the rubber is completely torn away from the metal pin that the bolt goes through.
But it never hurts to get under there with a small flashlight to see if you are able to see the rubber part of the mount.
Old Sep 13, 2011 | 09:17 AM
  #42
FlawleZ's Avatar
Would someone mind posting the Ebay motor mounts that they purchased and used? I see a lot and I'm skeptical if they're all listed correctly. IE I don't wanna buy mounts that say "fits 2003" but its for an '01 with VQ30DE-K.
Lakersallday24
Jun 16, 2019 01:35 AM
schmellyfart
Sep 25, 2015 04:47 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
laparka66
Aug 6, 2015 09:36 AM
