How do you put the motor back in timing?
Old Oct 8, 2010 | 01:54 PM
maximer's Avatar
I have an 03 6spd max. pulling off both heads because of a failed compression test, cyl#4 showed no compression what so ever. After a few test figured out that i had an intake valve(s) stuck open in that cylinder. So im pulling both heads off to do a 3 angle valve job, re-seal the valves, new head gaskets and i will be shaving the head .020 thousanths of an inch. Im not exactly sure how to put the cams back in timing. I've looked but couldnt find a how to thread on this.
Old Oct 8, 2010 | 02:06 PM
ghostrider17's Avatar
No answer for you -- but a question:
How was the car RUNNING before you got the compression test??
thks,
gr
Old Oct 8, 2010 | 02:19 PM
maximer's Avatar
well it started with a misfire, which got worse and worse and time went on. i got a p0335 and a p0300. so i removed the intake manifold to replace the spark plugs and check the coil packs in the rear of the motor only to find out i had to replace the valve cover due to a bad tube seal which i thought was where my misfire came from but i was wrong. since i had a p0335 (bad crank sensor code) i replaced the crank sensor and put everything back together...... and nothing. still getting the same bad misfire. the p0335 went away but the misfire did not. For some reason the misfires got even worse, to the point where the car wouldn't idle, unless i gave and held throttle, it would sputter to a stall. i then noticed i was getting backfires through my intake, and my IM smelled of gasoline. That lead me to the compression test confirming i had a bad intake valve, which brings me here today.
Old Oct 8, 2010 | 02:22 PM
MoncefA33's Avatar
Do you have access to the FSM? It will show you how to in there.
Old Oct 8, 2010 | 03:47 PM
maximer's Avatar
FSM? im not even sure i know what that is
Old Oct 8, 2010 | 05:32 PM
knight_yyz's Avatar
Toolie
field service manual
Old Oct 8, 2010 | 05:37 PM
TheArtist's Avatar
FSM is great and free online. enjoy!!
http://www.aubreyandcharles.com/NissanServiceManuals/
Old Oct 8, 2010 | 06:39 PM
CraigSE's Avatar
For sure use the FSM.
The VQ is a little trickier than some.. i did the timing on my Saturn and it was easy, but on the VQ it's got secondary and primary chains to time. Take your time.
Old Oct 9, 2010 | 07:37 AM
maximer's Avatar
I'll keep that in mind. All this help is appreciated . On a scale of 1-10 how hard would you this is to do? Im not the most mechanically inclined person in the world nor the least. I pick up stuff quite quickly the first time.
Old Oct 9, 2010 | 08:05 AM
zero2sixtyZ's Avatar
You embarrass me.
Factory Service Manual. But tomato, tomahto.
Finkle
Sep 27, 2015 09:53 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
doobadoo
Aug 15, 2015 06:43 PM
sc10692
Aug 9, 2015 09:37 AM
