Help Me
Old Dec 17, 2001 | 08:09 AM
crzyballa33's Avatar
Help Me
I got some new washer lights. I'm going to install them, but I don't know where to run the wires so that they turn on when I turn on my headlights. If someone has any information about this, please let me know.
Old Dec 17, 2001 | 08:21 AM
Sonic's Avatar
They are illegal to use, expect to be pulled over soon and ticketed for it. That'll be my advice.
Old Dec 17, 2001 | 08:23 AM
I understand that they are illegal, but I will install them anyway, if I can figure it out. If you don't know how to install them then don't respond to this post. THANK YOU.
Old Dec 17, 2001 | 08:25 AM
Sonic's Avatar
Old Dec 17, 2001 | 08:28 AM
Craig Mack's Avatar
All YOUR grammer belong to me
Old Dec 17, 2001 | 09:01 AM
clee130's Avatar
is your friend.
http://forums.maxima.org/search.php?...der=descending
Old Dec 17, 2001 | 02:03 PM
zman187's Avatar
Originally posted by yo_its_ok
Yes I agree...Indeed.
I concur, exactly its the right thing to do.
Understand ?
Actually a friend and i just wired them up. Its really not that hard. You just have to open your fuse box and connect the wire to the parkinglights, and then connect the constant wire to any nut or bolt. I live in NJ and I don't think they are illegal, but maybe I'm wrong. Hope I could help
Old Dec 17, 2001 | 02:12 PM
PhatGuy
Ditto. Plus the take away from a nice car such as a Maxima.
Old Dec 17, 2001 | 02:42 PM
bcannon's Avatar
http://www.riceboypage.com/
Old Dec 17, 2001 | 02:59 PM
SuDZ's Avatar
Originally posted by clee130
is your friend.
You have now upgraded to visual aids huh? I doubt they makea difference.
SuDZ
Greg's2kGLE's Avatar
Re: Help Me
Ok, to answer your question (unlike 7 out of 8 replies) here we go....I ran mine to the parking lights. Just take out the parking light (twist it) then disconnect the harness from the bulb. You have three wires running to the harness, RED, BLACK, and GREEN. RED is to make the parking lights go on, BLACK is ground and GREEN is to make them blink (but they don't stay on with the parking lights). Just take the wire and slide it into either the RED or the GREEN coresponding slot. I hooked mine up to the blinkers (GREEN). Then just put the harness back together, then just connect the BLACK wire (ground) to any metal bolt. check to make sure it works, then put back the bulb. Repeat for other side. It was pretty easy, easier than installing the suckers.
Now for those other 7 replies that didn't answer his question, please if you don't have anything related to his question or don't have an answer, don't reply. Sorry if I sound like an @$$hole, but it ****es me off when someone asks how to install something, then someone makes fun of the product. Grow up.
Old Dec 17, 2001 | 04:27 PM
Re: Re: Help Me
if i hook it up to the green wire, will they blink when i signal a turn?
thanks.
Old Dec 17, 2001 | 04:30 PM
Re: Re: Re: Help Me
thanks.
You are correct. But they do not stay on with the parking lights. I guess if you really want to, you could tap into the existing red wire from the LEDs and hook up another wire going to the red wire slot in the harness to have them on with the parking lights and blink with turn signals. I never tried it though.
Old Dec 17, 2001 | 04:35 PM
Re: Re: Re: Re: Help Me
i really just wanted them to come on with my headlights, so can i do the same thing except hook the red wire from the lights to the headlights? what color wire should i connect it to then u think?
Old Dec 17, 2001 | 04:41 PM
Re: Re: Re: Re: Re: Help Me
Well if you want them to come on with your headlights, the use the RED wire slot. Since the parking lights come on with the headlights, the LEDs will light up when the headlights are on. I haven't tried hooking them up directly to the headlights (at least not on my car). You can do it by taking out the bulb and stuff, but it is too complicated and hooking them up to the parking lights is easier and you get the same results.
Old Dec 17, 2001 | 04:45 PM
dmbmaxima2k2's Avatar
Maxima.org Sponsor and Donating Maxima.org Member
also if they are white or amber they are not illegal.
Old Dec 17, 2001 | 06:08 PM
Re: Re: Re: Re: Re: Re: Help Me
I'm not sure what you mean by parking lights. Are they the same thing as the turn signals? If they are, and i dont want them to blink, I just hook it up to the red and not the green right (last question sorry)?
Old Dec 17, 2001 | 06:35 PM
Re: Re: Re: Re: Re: Re: Re: Help Me
If you don't want them to blink, hook it up to the RED. The parking lights are the orange (if you haven't changed them) lights next to the headlights.
