How much oil to add after teardown?
Finally finished up my timing chains, tensioners, guides & water pump. I added 4 1/4 quarts started it up and took it for a test drive and it's running just fine. Let it sit overnight and checked the oil this morning and the dipstick is completely dry! How much oil do you have to add when the engine has been pulled apart and completely drained? There are no oil leaks either
hmpf - a quart shy should still show on the dipstick.
I'd go 1 1/4 or 1 1/2 more!
Good job Roasader!
Did you about **** yourself while you hit the ignition to start the engine?!?!
I tore my motorcycle engine down last winter for the first time....and the CLATTER it made when I first started-it-up was NERVE-RACKING!!
went-away in two seconds as the oil got back-into the cam-chain tensioners tho.
gr
Good job Roasader!
gr
May I just ask why you changed your timing components anyways?
On my car the timing side is whisper quiet and I figure its gotta be like new in there.
It was making a loud rattle at startup and it was gradually getting worse. When I opened it up one of the tensioners were bad and I decided I would replace everything while I was in there.
Good call on doing it all though. That is the right way!
My car does the same thing. But only for about a second when I start the car cold. I'll probably replace it eventually...but for now, the car runs fine. And it's one of those situations where if it ain't broke, don't fix it IMO...
My car had the rattle at start up from day one (when I purchased used two and a half years ago) but recently it started getting louder and lasting longer and I was just sick of it. Now she starts up beautifully with no rattle whatsoever, runs quieter too
05RLS2
Apr 14, 2016 11:49 AM
