ODD question perhaps!
Old Oct 14, 2010 | 08:14 AM
nismoSEXIMA's Avatar
i got into an accident last week and im waiting for insurance to send me a check....but my question is i have a 2003 maxima....is it possible to do a i35 front end swap? fenders,hood,grille and headlights?? has anyone ever attempted this or am i just filling my head with wishful thinking??? i was under the assumption these cars are pretty much the same car with different body pannels...
Old Oct 14, 2010 | 08:26 AM
Nelsito65's Avatar
I have to admit that the first thought that came to mind was if you were trying to put together some kind of "Max-kenstein" or a "Franken-xima".
Old Oct 14, 2010 | 08:39 AM
2000_MAXIMA_KING's Avatar
I think you probably can since they essentially use the same frame with just different bodys so you can swap in all the front panels since they would all fit together. The only question is will the fenders work with the maxima doors?
Btw someone correct me if I'm wrong.
Old Oct 14, 2010 | 08:40 AM
yeah i dont know if the doors are the same??? does anyone know if the doors are the same?
Old Oct 14, 2010 | 10:00 AM
Me either I think the doors on the max are more square edged then the i35 picturing it in my head I think there would be a gap in the middle of where the fender and door meet and the upper and lower corners may rub with the door. Find an i35 and max in one piece and make some measurements.
Old Oct 16, 2010 | 09:45 AM
could someone with an i35/i30 please post a pic of there radiator support so i can compare it to mine...
Old Oct 16, 2010 | 10:47 AM
maxima dude's Avatar
yes its bi done before by only 1 guy i kno of... it can be done and i believe everything lines up perfect =)
Old Oct 16, 2010 | 12:22 PM
Mr. Brett's Avatar
Pretty sure they're identical where the fender meets the door.
But you can be the judge, OP.
Old Oct 16, 2010 | 12:56 PM
Looks like it would work from the pics I believe it does since there are a couple people who haved swapped to the i35 hood so it should work another member just said someone did it so to the op go for it.
Old Oct 17, 2010 | 03:50 PM
CMax03's Avatar
The I30/I35 don't have fender flares....so even if you switch out the front fenders, hood, grill, it'll look kinda weird, the body lines are slightly different as well!
Old Oct 17, 2010 | 04:24 PM
VQ'rInWLA's Avatar
^ True but you can just have the fenders pulled up front. From the pics, it looks as if the doors would line up.
More power to you if you pull this off. VW's are known for these kind of conversions (miss the VW scene). MK3 GTI's with a Jetta front end thus converting it into a JTI. They were sicc. So a Max with an I front end would be what? An IMax?
Unclejunebug
Apr 2, 2016 05:42 AM
trsandrew
Oct 25, 2015 02:47 PM
Stagnet04
Oct 11, 2015 08:16 PM
Socalstillen
Sep 26, 2015 12:01 PM
