A real 0-100mph Thread.
Old Oct 18, 2010 | 05:57 PM
perkman87's Avatar
Okay Orgers,
mounted the cam on a custom pod and went ahead and shot this. Trying to shift with a pod in your face made me a little agitated and I mis-shifted
(hence the second part of the video) and a new mounting location. could not do from a dead stop because of traction issues and the camera bouncing everywhere, these are not the best, as in my driving performance, but they will do.
Enjoy!
Old Oct 18, 2010 | 06:05 PM
perkman87's Avatar
Originally Posted by scarface4522
slow..
yup it is slow. Its a maxima
Old Oct 18, 2010 | 06:07 PM
perkman87's Avatar
and you can see the converter lock up in 3rd.
Old Oct 18, 2010 | 06:12 PM
junglee Z's Avatar
have you had any problems with the transmission from using the DR mod? my I35's transmission was slightly slipping when i did that mod, but after using it a few times, it took a crap fast! btw, how much power are you puttin down to the wheels? and which dyno was it on?
MoncefA33's Avatar
Mis-shifted an automatic
Old Oct 18, 2010 | 06:17 PM
perkman87's Avatar
Only way to make it shift faster and rev farther with the dr mod
Old Oct 18, 2010 | 06:31 PM
Crusher103's Avatar
Old Oct 18, 2010 | 06:36 PM
perkman87's Avatar
If you watch my Safc you can see me feathering all of first.
Old Oct 18, 2010 | 07:03 PM
jeff5347's Avatar
Perkman, it looked like in 3rd at 5k there was a slight hover, or were you feathering at that time. It happens in both takes
Old Oct 18, 2010 | 07:04 PM
Mr. Brett's Avatar
Bog in powerband = torque converter locking.
Old Oct 18, 2010 | 07:05 PM
perkman87's Avatar
yes
perkman87's Avatar
thst is the torq converter locking up, even your car would do that if you had full pressure going through the transmission from gears 1-3.
Old Oct 18, 2010 | 07:54 PM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
clocks out about 16.1 on the second run and 16.7 in the first right?
i missed the banned run....about what was the timing on that?
i havent played with gate shifting yet...i did a run but ive just tried in d. does it really make a difference in going with gate shifting? cant get the stupid thing to hook up at all...yet...
want to start tuning. considering the afc route...
Old Oct 18, 2010 | 07:59 PM
carrrnuttt's Avatar
Not exactly 0-100 (when I was still almost stock)...
Wait. This IS the show & tell thread, right?
Old Oct 18, 2010 | 08:01 PM
perkman87's Avatar
prob, but Im doubting clocking on this video will do much for real times.
Im at 100 in the quarter mile -14.2
Old Oct 18, 2010 | 08:03 PM
perkman87's Avatar
HELLLL YESSSSS!! Sick
Old Oct 18, 2010 | 08:34 PM
scarface4522's Avatar
I was gonna ask u about that but i figured it was normal...Does it do in when left in D?
Originally Posted by perkman87
Correct that sounds right. But its tough to say as I am rolling. and feathering due to traction. i only feather first for like .3 sec then when it gets traction full throttle, one thing i noticed was every time i shifted the tranny my safc would read blank.......
perkman87's Avatar
nope.
Old Oct 18, 2010 | 09:01 PM
Chocolate_Boi_1Der
lol thats why i was asking, traction is moreso an issue in anything other than d so i usually just run from 3 if anything. was curious.
Old Oct 19, 2010 | 07:03 AM
NmexMAX's Avatar
dot dot dot ...
nope.
Lock up wont occur in D, and with that said the 'lag' will be gone, but it sill shift 'early'.
Old Oct 19, 2010 | 08:09 AM
njmaxseltd's Avatar
Lock up wount occur at WOT either.
Old Oct 19, 2010 | 11:52 AM
NmexMAX's Avatar
dot dot dot ...
Whatever that lag is occurs @ WOT though, and only in 3rd.
Old Oct 19, 2010 | 12:15 PM
Chocolate_Boi_1Der
and im tracking on the raised limiter when gate shifting, but figured without cams the powertrain or cams to capitalize it would be a moot point to do so.
due to fears of the tranny commiting self murder i usually do any runs from a roll and if its one where im concerned about the other car i go from third. realizing the higher revs may help a little i look at an auto as being able to stay pretty consistent just as long as the driver can launch consisitently. didnt really realize it would seriously drop times gate shifting.
Old Oct 19, 2010 | 12:24 PM
MoncefA33's Avatar
Buy some 17" wheels already.
Old Oct 19, 2010 | 12:25 PM
NmexMAX's Avatar
dot dot dot ...
I gate shift in order to utilize the extended rev limiter, so i see your point.
Also, the tranny fluid temp needs to be at temperature before lock-up occurs (shift to 4th).
I have some dynos and data logs from 4th gens, 5th gens, 5.5 gens and 6th gens that verify that they both exhibit the same behavior in a certain gear. I cannot remember the 6th gen, but the 4th and 5th is 3rd.
Old Oct 19, 2010 | 11:03 PM
CMax03's Avatar
Needs more tuning! Running too rich or too lean!
Or intake system too long!
Old Oct 20, 2010 | 01:22 AM
MoncefA33's Avatar
At 0:35 seconds your SAFC completely drops the RPM signal.
Old Oct 20, 2010 | 01:25 AM
MoncefA33's Avatar
Start at 1:30
Old Oct 20, 2010 | 05:38 AM
Chocolate_Boi_1Der
hell to the nah.....spin them heavy *** 19s. All day
Old Oct 20, 2010 | 05:47 AM
perkman87's Avatar
that happens when i gate shift it.
Old Oct 20, 2010 | 06:08 AM
NmexMAX's Avatar
dot dot dot ...
It does not occur in 4th(OD) or 2nd or 1st.
Myself, Jime and Nietzsche have proven this with data logging/capture.
See what happens@ 4.5k?
Here's RPM vs MPH
That's not an intake issue or 'tuning' issue, it's the tranny. The loop occurs because the RPM's subside by a couple or few hundred RPM, that's the reason for the reverse loop. Notice the linear speed curve, this is a 6th gen 3rd gear (5AT), but the 3rd gear in the 5th gen does the same.
Hmm, Ceffy, that’s a good observation. Very interesting. I wonder what that could be. Mine does not do that whether or not I gate shift, and it seems to be only during the shift.
At first I thought maybe it could be the throttle closing during the shift, but it all goes away, RPM and all. Hmm.
Old Oct 20, 2010 | 06:25 AM
perkman87's Avatar
If I leave it in Drive the SAFC reads all the way to redline. I think it breaks communication with the ecu when I do the manual shift.
something I would have never noticed, as i do not stare art the safc when going wot lol.
could this be because I modulate the pedal during the shift as well? like i get off it then back on it...
Old Oct 20, 2010 | 06:26 AM
NmexMAX's Avatar
dot dot dot ...
Why modulate it? Just wondering. But the RPM's die, and the throttle seems to stay at wherever it truly is, as in does not lost signal.
Old Oct 20, 2010 | 06:27 AM
perkman87's Avatar
and should i immediately shift to d after 1-2 shift.
NmexMAX's Avatar
dot dot dot ...
After 2-3. So go from 2 - D. If @ WOT, it will hold 3rd until 6k or whenever the TCM wants to shift (usually @ or around 6k).
Old Oct 20, 2010 | 06:31 AM
Deckdout2's Avatar
Play with my balls
I want to play......
Not sure if you can see the cluster all to well, but close.
Fresh build, no tune, jumped time 15*, and a couple other codes. Baseline fun run.
Old Oct 20, 2010 | 06:34 AM
perkman87's Avatar
I love the WOT shifts
Old Oct 20, 2010 | 06:35 AM
perkman87's Avatar
ugh I hate that i can normally get it to go to 6700 manually.
Old Oct 20, 2010 | 06:36 AM
Deckdout2's Avatar
Play with my balls
Me too.
NmexMAX's Avatar
dot dot dot ...
