Mass airflow sensor
Old Oct 21, 2010 | 02:31 PM
bgsl1ck's Avatar
Mass airflow sensor
Ok so I have been reading and searching for days I have a 2k2 with MAS problems my question is. I saw that some people changed to a 2K1 MAS and moved the IAT resistor.
Is it possible that the resistor is bad and doing so would only give you the same problem?
I know it's the better move as far a price goes. but what other options do I have.
There was a thread with pictures of the IAT swap does anyone know where it went.
Sorry tried the search and came up empty..
Thanks in advance.....
Old Oct 21, 2010 | 03:26 PM
TallTom's Avatar
The piece you swap is a thermistor and the likelihood of that simple part failing is like 1%. When my MAF fails, I will be buying the 2k1 MAF and doing the swap.
This is the URL you are looking for: http://forums.maxima.org/5th-generat...-pictures.html
Old Oct 21, 2010 | 03:35 PM
bgsl1ck's Avatar
Thank you I'm on my way to courtesy right now
Old Oct 21, 2010 | 04:15 PM
rosader's Avatar
Interesting, I wonder if anyone has had any issues later on when swapping the thermister over. Why the F*** would Nissan charge so much if thats the only difference between the two?
Old Oct 21, 2010 | 05:28 PM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
cause majority of people dont have the resource of a forum like this to tell them that the only change is that.
Old Oct 21, 2010 | 05:45 PM
TallTom's Avatar
The only issue I noticed about the swap is when you don't secure the thermistor well enough. You really need to lock it in there to make sure it has a permanent contact.
Old Oct 21, 2010 | 09:19 PM
alcala87's Avatar
I just recently installed the 2k1 MAF into my 2k2 and swapped the thermistor. It came with a piece of paper to reprogram the ECM to countermeasure specifications and provided a TSB # but since it was for a 2k1 i did the ECM reprogram countermeasure procedure for the 2k2 sensor. It has been in for almost a month now and I haven't had any problems.
TallTom
57
Oct 14, 2025 05:16 PM
my03maxima
Jul 28, 2024 07:40 AM
Kyle Lee Cleveland
Sep 28, 2015 09:01 PM
