Rattle
Rattle
I have a 02 max with.143xxx on it, and I am getting this rattling noise. When I start the car when it's cold it doesn't do it, when the car is warm while it's in neutral idling I give it a little gas and it makes a rattling noise. I checked the exhaust system and the heat shield still getting it. It sounds like it's coming from the engine or underneath. What could this be? Thanks
Check this thread, does it sound the same?
http://forums.maxima.org/5th-generat...er-reving.html
The inside of the cat just came loose. It didn't break in pieces or anything, but the entire thing inside was loose and no longer attached to the metallic shell of the cat.
tip: if you need to replace your cat, ask your mechanic if you can get the old one back. I brought mine to a recycling place and got $70 for it
lrb6805
Sep 17, 2015 04:49 PM
