Changing MT gear lube
Old Nov 4, 2010 | 09:36 PM
  #41
Eirik's Avatar
Originally Posted by nelledge
I think he is referring to the fact that you specified the six-speed Nissan transmissions.
Oh. I'm not saying it's BAD for our transmissions or whatever, just that the MT-85 seems much more suited (read, engineered specifically for) our transmissions. They are both fine, but MT-85 is more fine.
Why are these boards relevant to this claim? Nissan 6spd evaluations are all the matters IMO.
Because I read what sorts of applications people found MTG to work best in. The transmissions folks found the best results in aren't made like ours--they have different sorts of metals inside, are being used in completely different applications, or both. Heck, I can even quote AMSOIL's page on MTG, " It is formulated specifically for maximum protection in the most demanding manual transmission and transaxle applications where an extreme pressure GL-4 gear lube is specified, including those where high horsepower/high torque engines and towing or heavy loads increase transmission stress."
They go on to cite its advantages for use in medium-duty trucks and muscle cars. They last time I checked, my six-speed would shatter if it hooked up to a 26000 lb Hino chassis or 1000HP drag racer.
Again, Red Line says, "Recommended for Nissan 350Z and 370Z (also most Maxima, Altima & Sentra)" on their MT-85 page and, "We think this fluid will be a hit with Nissan Z-car fans and Mitsubishi Evolution owners, as well as gear oil customers for a viscosity in between our MTL and MT-90." They made it for us! Just for us! ...Okay, not really, but it hits that sweet spot between MTL and MTG/MT-90.
The thicker weight of the MTG vs the MT-85 is simply not needed. 14.7/84.5 vs 12/64.3 @ 100C/40C, pour points of -51F vs -54F... I'm not seeing why anyone would want their six-speed powering through the added slush in the MTG, unless they lived in a metropolitan area in Texas with 2 million people.
I'd love to read more scientific evaluations of MTG vs MT-85 or MT-90 in the Nissan transmissions, but Google was only yielding intelligent posts by other manufacturer's fan boys. =/
You think that's bad? I live in a metropolitan area of 2 million people and had to order both the Redline MT90 and the Amsoil MTG.
Shhh, don't shatter my dreams of living in a real city with more amenities someday.
Old Nov 5, 2010 | 03:48 PM
  #42
kbohip's Avatar
God Dangit! For four years I run MT-90 and now afterI order MTG, Redline introduces something that might have been what I needed all along! Oh well, I'll give you my thoughts on the MTG and you give me your's on the MT-85 ok? If I start hearing miraculous things like "my 3rd gear crunch is gone" though from many different members I'll probably switch over sooner rather than later.
Old Nov 5, 2010 | 03:53 PM
  #43
trooplewis's Avatar
In my car, 3rd gear is smooth as silk.
Now 4th gear, that one is a notchy b*tch
Old Nov 5, 2010 | 11:35 PM
  #44
kbohip's Avatar
3rd gear is strange for me. Sometimes it's notchy as can be, while others it's as smooth as silk. I have noticed that as the car heats up and the weather is very hot, 3rd is smooth 99% of the time. It's when the car is in the warmup period that it crunches.
I guess I pay a lot more attention to this than most though as I used to have an '88 Toyota MR2 Supercharged that had plenty of bad synchros. I'm talking double clutch or people walking along the road hear me grinding gears bad. I worry that one day my Max will get to this point.
Old Nov 6, 2010 | 08:51 AM
  #45
Eirik's Avatar
Heh, well, that's how the cookie crumbles? I decided to pull the trigger on the MT-85, got it from Z1 Motorsports, so I'll wait for it to get here and find where I can buy this hex reverse socket thing.
I don't have a third gear "crunch," I don't think, but sometimes it makes a noise/sort of feels like it buzzes off the synchros when I shift it in. I've always chalked it up to a bad, sloppy, or otherwise lazy shift. I'll do a proper writeup in this thread in two weeks or so.
Edit: Er, well, I chose to checkout with PayPal and when it directed me back to the Z1 site, it didn't give me an order number and claims I haven't ordered anything. Broken implementation of PayPal? I guess I'll wait and see if anything hits my bank account before reordering using their system. =/
Old Nov 6, 2010 | 11:10 AM
  #46
mahanddeem's Avatar
1st I'm sorry , no intention to hijack the thread , but don't want to open a new one ....Do you guys think I would need a new (or 2 new) gaskets for the fill and drain plugs ? or just give it a shot and change the oil straight away ? hate to order and wait for shipping....got my 02 6spd at 118k miles , unkown if the gear oil was replaced before or not ....
Old Nov 6, 2010 | 11:29 AM
  #47
J-Rod's Avatar
Originally Posted by Majestic Ken
Royal Purple FTW. Check orilleys. kinda pricey but you want it to run good forever.
like a little over $17/qt... but it's what is in mine.
Old Nov 6, 2010 | 11:31 AM
  #48
trooplewis's Avatar
The old gaskets should work just fine.
They will probably last longer than the rest of the car does.
  #49
J-Rod's Avatar
Originally Posted by shaidarharan
No, I do not have an automatic but the FSM refers to the code as a "park/neutral switch" sensor error. It's actual the neutral/reverse sensor judging by the effects.
if you don't mind the code, and or the effect (no back up lights) it really isn't a must to change. On our manuals that is the only purpose is to turn on the "back up lights" which mine haven't been working for about 7yrs now. I will change the sensor eventually... probably like you, when its time to re-do my transaxle oil. That is the best time to do it.
Edit: oh yeah and the code is just stored it doesn't throw a check engine light, or at least it doesn't on mine.
double edit: and no I don't care if the back up lights work, really not a problem for me... generally that rev of the motor and my pipes get the attention I need to let them know I'm coming.
Old Nov 7, 2010 | 06:45 AM
  #50
Eirik's Avatar
Wow!! That's... A lot. The Z1 thing went through for me and the final cost was $15.80 a quart, shipping and tax included. It was $10.98 a quart before shipping.
Guy in Lexington: Woah... I never would have though someone in Lexington owned a Maxima six-speed! That's way too sophisticated and Japanese a product to show up there, I would have thought.
Old Nov 7, 2010 | 06:54 AM
  #51
mahanddeem's Avatar
In fact I know few guys in Lex who have 5.5gen 6SPD,so I'm not the first one
Old Nov 8, 2010 | 06:48 PM
  #52
mickeyiz28's Avatar
I'm in Richmond and have a 6spd as well, I have to replace my fluid here also, so has anyone figured out which is the most preferred?
Old Nov 8, 2010 | 06:49 PM
  #53
mahanddeem's Avatar
I ordered Amsoil from talkinghorse...PM him,he's a very nice guy...
sctludwig
Sep 1, 2022 01:32 PM
Mar 12, 2020 12:06 AM
pjgreek
Sep 9, 2015 09:30 PM
dcardello
Sep 3, 2015 11:44 PM
