I dont mean to beat a dead horese, but.....
Old Oct 27, 2010 | 08:05 AM
ricerocket336's Avatar
ive serchred and i have got no correct answer, Im once again looking to do the 6th gen BBK upgrade. my question is what year/ years can i use the front calipers and brackets from the 6th gen maxima on my 03 maxima? please let me know thanks
Old Oct 27, 2010 | 08:14 AM
phatboislim's Avatar
04-08
Old Oct 27, 2010 | 08:37 AM
Thanks Phatboislim, i located a set off on 08 maxima, so they will 100% work right? i just need to reuse use my stock lines
Old Oct 27, 2010 | 08:39 AM
from what i've been told yes stock lines are still useable. 6th gen front brakes (calipers, caliper brackets, rotors, pads) are what are used for the BBK
Old Oct 27, 2010 | 08:42 AM
okay, thanks man, appreciate the quick responce
Old Oct 27, 2010 | 08:45 AM
no problem..se-r brakes work as well
Old Oct 27, 2010 | 09:01 AM
really, intresting.... hmmm
Old Oct 27, 2010 | 09:36 AM
GBAUER's Avatar
I did.
You simply replace the calipers and rotors. It's a direct bolt-on however the rims might not clear the calipers. You might need spacers. I had stock 5.5 gen rims on mine and without the spacers they hit (barely) when hard cornering.
Old Oct 27, 2010 | 10:16 AM
he said he had an 03 so i assumed, that he had 17" oem, at least......
Old Oct 27, 2010 | 10:58 AM
GBAUER's Avatar
Yes well he's not the only one reading this so...
Old Oct 27, 2010 | 10:59 AM
good point
Old Oct 27, 2010 | 11:08 AM
GBAUER's Avatar
BTW: What's a horese? Sounds, er, interesting....
Old Oct 27, 2010 | 11:28 AM
EL OH EL i'm not getting started on this one
Old Oct 27, 2010 | 02:47 PM
01-maxima-24's Avatar
I used 06 calipers and brackets, no clearance issues with 5.5 gen 17's here.
Old Oct 27, 2010 | 03:01 PM
OOmaxSE's Avatar
04-08 brake upgrade will fit under stock 02-03 SE wheels. They will not clear the 00-01 SE 17" wheels, however.
Old Oct 27, 2010 | 04:00 PM
Originally Posted by GBAUER
I did.
i have an 03 maxima with the TE wheels, from what i read on here they will and should fit without any issues. thanks for the heads up
lol i mis spelled horse hahaha
nice, i just ordered a set of calipers and brackets off a wrecked 08 maxima
Thanks man, appreciate it, so i should have no issues at all fitting them under my 5.5 SE TE wheels
Old Oct 27, 2010 | 05:18 PM
rroderiques77's Avatar
Demodded and Forgotten
HEEEEE HAAAAWWWWW
Old Oct 27, 2010 | 06:10 PM
Originally Posted by rroderiques77
HEEEEE HAAAAWWWWW
HAHAHAHAHAHAHAHAHAHH
Old Oct 28, 2010 | 05:12 AM
unless you get at least a 5mm spacer. the 00-01 are +45 offset and i'm imagining the 02-03 wheels are +40, hence the possibilility for clearanc, hence the minimimum of 5mm spacer needed
Old Oct 28, 2010 | 05:47 AM
Eirik's Avatar
Do not forget the caliper mounting bracket! Some junkyards quietly "forget" to send those, too, and most places get confused if you talk about just buying the bracket. You're looking for a semi-loaded caliper, as you already know and ordered.
Old Oct 28, 2010 | 05:48 AM
mounting bracket? this isnt the cobra bbk
Old Oct 28, 2010 | 06:01 AM
Deckdout2's Avatar
Play with my balls
Old Oct 28, 2010 | 06:23 AM
NmexMAX's Avatar
dot dot dot ...
You fellas kill me.
Old Oct 28, 2010 | 08:06 AM
Deckdout2's Avatar
Play with my balls
Originally Posted by NmexMAX
You fellas kill me.
BOOM! Headshot.
Old Oct 28, 2010 | 09:09 AM
NmexMAX's Avatar
dot dot dot ...
The only thing I bought with my "BBK" were new pads, calipers and rotors. Everything else was fine.
Old Oct 28, 2010 | 10:21 AM
Prophecy99's Avatar
yes agreed +4
Old Oct 28, 2010 | 12:44 PM
yes, i made sure that they were included, is what the guy told me when i ordered them i will receive: Brake caliper, brake caliper mount bracket, all the metal shims in the caliper, all the mounting bolts and slide pins, brake pads with shims, and the stock cut lines. all off a 2008 maxima
Old Oct 28, 2010 | 01:14 PM
BlackMacks's Avatar
So if I'm getting close to needing new front pads and rotors anyway, you're saying all I need to shell out money for "extra" is the front calipers from a 6th gen?
Well hell why doesn't everyone do that?
Old Oct 28, 2010 | 01:35 PM
^x2 i feel alot of softened brakes lately and that means its time for an upgrade
Old Oct 28, 2010 | 03:35 PM
NmexMAX's Avatar
dot dot dot ...
You need all 6th gen hardware... calipers, pads and rotors.
Old Oct 29, 2010 | 02:26 AM
is that just for the 5.5 or both 5 and 5.5?
Old Oct 29, 2010 | 02:33 AM
NmexMAX's Avatar
dot dot dot ...
6th gen ... wookie. 5.5...= Caliper, Rotor, that is all.
Old Oct 29, 2010 | 04:34 AM
ahhh this is new info to me...either way still wont work on my 5th..i'd have to still get the works, but good to know
Old Oct 29, 2010 | 04:36 AM
BlackMacks's Avatar
Sorry, Nmex, I should have clarified my question, I understood what you originally said. I was referring to buying 6th gen rotors and pads since I needed new rotors and pads anyway, and the only "extra" purchase would be the 6th gen calipers.
Yeah, this is what I'll be doing, when it comes time to do my front brakes.
HOKUSMAX
Nov 13, 2017 04:34 AM
doctorpullit
Apr 23, 2017 05:35 AM
pktaske
May 6, 2016 07:49 AM
markevans999
Sep 10, 2015 04:29 PM
pktaske
Sep 4, 2015 08:40 AM
