ABS issue
Old Oct 27, 2010 | 02:33 PM
HotshotVQ35's Avatar
ABS issue
ok, long story short when its wet out, my abs kicks in all the time, and yet the light never came on. so, i would just pull the fuse when it rains and problem temporally fixed(would rather drive with no abs than destroy it). this has been going on for months. well, today, it POURED, and of course the abs kicked in all the time, but for the 1st time, the abs light actually came on! im going to my buds house on sat, i am thinking the sensor has some dirt/grime in there, since the problem was never consistent. anything else you guys can think of while i have the wheels off?
Old Oct 27, 2010 | 04:08 PM
vinco's Avatar
Pulling the fuse isn't going to keep anything from destroying itself. Maybe it's "kicking in" because your brakes are actually grabbing hard and trying to lock up. It certainly won't hurt anything to clean up the pickups and the cog rings. Just be careful with the sensors, as they are just thin plastic wrapped around a very fine wire winding, with thin metal inserts. Don't pry on them any unless you want to replace them. A shop or individual with a Consult II scanner would be able to scan ABS codes, if there are any. A regular engine scan tool won't do it.
Old Oct 28, 2010 | 09:39 AM
any other ideas people
Old Oct 28, 2010 | 09:46 AM
NmexMAX's Avatar
dot dot dot ...
Until you remove that wheel and take a look, not really.
So what's the symptom, it kicks in when it shouldn't?
Old Oct 28, 2010 | 03:52 PM
exactly, when i brake from 10mph it kicks in. it pretty much kicks in at all low speeds..
Old Oct 28, 2010 | 04:02 PM
trooplewis's Avatar
I understand that on the 5th gen you need to spray off the ABS sensors at the wheels with brake cleaner every 30 or 40 thousand miles.
That would be the simplest solution for you if it works, and it is consistent with the symptoms you are getting.
Old Oct 28, 2010 | 04:11 PM
VQP0WER's Avatar
If your reluctor ring in the hub is damaged, or a incorrect gap, it will cause your issues. The system thinks your sensor is working properly, hence why there is no ABS light.
Old Oct 28, 2010 | 06:53 PM
NmexMAX's Avatar
dot dot dot ...
5.0 eh?
Old Oct 29, 2010 | 09:18 AM
Froggmann's Avatar
Well if it only happens when it rains then start looking at the wiring and inspect the ABS plugs. Sounds to me like they may be shorting out.
mvm062
Nov 30, 2020 09:00 AM
bbsitum
Sep 6, 2019 07:31 PM
wingnut2006
Sep 19, 2015 06:13 AM
Djsmaxima
Sep 14, 2015 11:58 PM
maximusrising
Sep 2, 2015 09:55 AM
