02 Sensor code?? Confused
Old Oct 30, 2010 | 04:47 PM
2010MaximaSV's Avatar
So i went to autozone since my check engine light came on and the codes are p0139 and p1147. Im guessing this is bank 1 sensor 2 correct? On the sticky thread in the picture it shows it on the right side, but isnt bank 1 on the left side??? Also is the bosh 15224 the right part number? Are these fairly easy to get to?
Old Oct 30, 2010 | 08:27 PM
DennisMik's Avatar
For a 2002 max both P0139 & P1147 are both for O2 sensor #2 located before the cat converter. Sorry but I don't know the part number but no one seems to have a problem getting replacements.
you should be able to get them at most auto stores.
Old Oct 31, 2010 | 02:43 PM
Anyone else have any input?
Old Nov 1, 2010 | 07:25 AM
ColdRain's Avatar
check the last sticky in the list.
Old Nov 1, 2010 | 02:52 PM
yeah thats where I was looking and in the picture its on the right side but auto parts told me its on the left, so I need to know the part number.
Old Nov 2, 2010 | 01:57 AM
DennisMik's Avatar
Left and right sides of an engine (or the entire car for that matter) are based on you sitting inside of a car that is built as a rear wheel drive car. The front of the engine has the crank shaft pulley, while the rear of the engine has the flywheel and the starter. In the Maximas with front wheel drive, the crankshaft pulley is pointing at the left wheel and the left side of the engine (bank) is towards the rear.
I don't think that the auto manufacturers ever agreed that bank 1 means right or left side
The sticky shows that codes P0139 & P1147 come from the right side O2 sensor, closest to the firewall. This sensor is color coded blue by Nissan. Bosch sensor 15225 is for the right side and is conveniently color coded blue.
Old Nov 3, 2010 | 06:30 PM
I was told that its bosch 15224 can anyone clarify this?
Old Nov 4, 2010 | 02:37 AM
DennisMik's Avatar
left side = Bosch 15224, color code red.
right side = Bosch 15225, color code blue.
P0139 & P1147 relate to the right side
http://www.rockauto.com/catalog/x,ca...,parttype,5132
Read and heed the sticky, NOT the parts guy...
Old Nov 6, 2010 | 12:59 AM
Saadkhan07's Avatar
re
i got the same thing going on....i changed the plug with a NTK 24618. bought on ebay for $100 ( cheap)
however, the 139 code is gone, but 1147 is still around...i have NO idea as to why !
thats why i am here trying to figure it out ! someone said the ECU will reprogram automatically.....but i doubt it
mvm062
Nov 30, 2020 09:00 AM
220k+ A32
18
Sep 22, 2015 11:39 AM
DarjeelingRose
Sep 15, 2015 01:20 AM
