How to get some low end power?
Old Nov 7, 2010 | 12:39 PM
Youraveragekit's Avatar
Anyone have any suggestions on how to gain low end power?
Old Nov 7, 2010 | 01:48 PM
Child_uv_KoRn's Avatar
Bad *** Newb
Don't modify anything?
Old Nov 7, 2010 | 01:59 PM
CMax03's Avatar
SRI, 2.5" Bpipe & Oem rear muffler!
Old Nov 7, 2010 | 03:03 PM
T_Behr904's Avatar
Old Nov 7, 2010 | 03:09 PM
MizzMaxine's Avatar
Lightweight Under Drive Pulley, Lightened Flywheel, Turbo.
Old Nov 7, 2010 | 03:10 PM
tookrzy4u192's Avatar
Get some lightweight wheels
Old Nov 7, 2010 | 03:16 PM
Unklejoe's Avatar
100% correct. Most mods for the Maxima sacrifice low end power to gain top end power.
One mod that is good for low end power is NWP's intake spacer kit.
Old Nov 7, 2010 | 06:25 PM
DCZC's Avatar
[quote=Unklejoe;7804783]100% correct. Most mods for the Maxima sacrifice low end power to gain top end power.
One mod that is good for low end power is NWP's intake spacer kit.[/quote]
Since he has a 5th gen with the plastic uim, would there really be any benefit?
I have considered it myself but have yet to see a dyno yield anything to speak of.
Old Nov 7, 2010 | 06:39 PM
CMax03's Avatar
intake and highflow cat first.......cooler iridium plugs!
Old Nov 7, 2010 | 06:51 PM
trooplewis's Avatar
Probably the "do nothing" will yield the best low-end power retention.
Old Nov 7, 2010 | 06:55 PM
A 35+ shot of nitrous will give you a nice boost
Old Nov 7, 2010 | 07:04 PM
DCZC's Avatar
Old Nov 7, 2010 | 07:20 PM
LongIslandMax's Avatar
Ehhh?
Get some lightweight wheels.
Old Nov 7, 2010 | 07:48 PM
True CAI.
Old Nov 7, 2010 | 09:33 PM
Rods03Max619's Avatar
I say Intake, Spacers, and Pulley, best out of those is those NWP Spacers!!
Old Nov 7, 2010 | 10:02 PM
jowo9's Avatar
I was amazed with the low end torque my NWP spacers added. I would also like to voice my to NWP Spacers for this application (or for everyone with a 5.5 gen Maxima ).
Old Nov 7, 2010 | 10:05 PM
I have a 5th gen, not 5.5 if that helps anyone.
Old Nov 8, 2010 | 05:59 AM
tedo007's Avatar
faster than you think
Get on Diet!
Old Nov 8, 2010 | 06:04 AM
ghostrider17's Avatar
Everybody seems to be pleased with this mod.
i think I'll consider this when i go back to replace my VC's in the next 25k miles, or so.
Or whenever the oil starts pooling in the spark plugs again.
Nice job Nissan!
Mental note: NEver buy a 1stgen MOTOR revision on a new car AGAIN!
gr
Old Nov 8, 2010 | 08:17 AM
MaximusTi's Avatar
17 Degree Timing Advance.
Lightest 17" wheels you can find.
Lightened flywheel.
Lightweight crank pulley.
Grounding Kit.
Good luck.
Old Nov 8, 2010 | 08:41 AM
Chris Gregg's Avatar
Get Off My Lawn
-1 on the turbo and Nitros. Those will NOT help low end.
Although it's been mentioned as the "do nothing" suggestion. I would expand to say no modification....but you SHOULD ensure your car is properly maintained (fuel filter replaced, change oil regular intervals, PCV valve, Platn. Plugs, and running 93+ Octane.
+1 on everything else mentioned. I would also add Aaron's (NWP) torque link. That should help put the power down.
Overall, you've got a lot of options. Just a question of cost. Opinions about what would be MOST effective or where to start is going to be individualized. But I would suggest starting on the basic stuff like maintenance, lighter wheels and components, and the torque brace....things to help cut the LOSS of power and the ability for the engine/transmission to get the power to the ground.
Old Nov 8, 2010 | 09:37 AM
Rochester's Avatar
Don't get too excited about what comes with a lightweight crank pulley.
However, a lightweight flywheel... that would be nice.
Old Nov 8, 2010 | 09:48 AM
MoncefA33's Avatar
I like mine.
Make sure your knock sensor & MAF are working properly, I drove my friend's 2001 AE last weekend and it felt like it had 5x more low-end power than my car, and it had stock exhaust, stock airbox, stock VIAS assembly, compared to my short ram (reduces low-end power), header & cat-back, and gutted VIAS setup. Most breathing mods shift the powerband to the right, so +1 for the "do nothing".
Old Nov 8, 2010 | 06:16 PM
T_Behr904's Avatar
I hear good things about the intake spacers for the 3.5, but are they also available for the 3.0 DE-K? If so I want to get those!
Old Nov 8, 2010 | 06:26 PM
T_Behr904's Avatar
The best way to add low end if your budget allows is supercharging. My GTP has GOBS of low end and mid range torque! And when I had the Eaton blower rebuilt, I also had it ported and installed a 3.4 in pulley which then destroyed my torque mounts
Old Nov 9, 2010 | 06:22 AM
Prophecy99's Avatar
I like mine.
im lost... one says SRI, one says SRI reduces?
Old Nov 9, 2010 | 06:48 AM
rroderiques77's Avatar
Demodded and Forgotten
SRI with tune that is.
Old Nov 9, 2010 | 06:52 AM
Crusher103's Avatar
some of u are giving the dumbest suggestion, i seriously hope 3/4 of you arent serious.
Old Nov 9, 2010 | 06:04 PM
T_Behr904's Avatar
Sea Foam the fallopian tubes and that **** will run like a cheetah on cocaine!
Old Nov 9, 2010 | 06:32 PM
Unklejoe's Avatar
Didn't notice he had a 5th gen. F the intake spacers then...save the money for gas.
They're FTW for the 5.5 though
Old Nov 9, 2010 | 07:34 PM
AlexxSCM's Avatar
take off the hood. ... and the trunk and seats.
...also the back seats, and doors and windows and ac.
and the headlights.
:/ long headers!!!!!!!!!!! super extra long headers!!!!
Old Nov 10, 2010 | 06:58 AM
CMax03's Avatar
Read the whole thing please! An SRI such as JWT retaining the Helmholtz chamber, going with a HighFlow cat, and either retaining the stock bpipe or upgrading to a 2.5" bpipe only! While retaining the OEM (Trick/variable flow muffler) will enhance your lowend > to> Topend! I ran this setup for years and it's awesome, and it's crazy with Cattman headers.....You have super linear throttle response all over the rpm range.....I swear by it! This is why I haven't sold my 2.5" catback...If I ever get my GTECH to work on my new computer I'll be able to see how my previous setup (above) and my 3" Cattman catback compare....believe me it's doesn't sound modified until you put it to the floor or past 1/2 throttle...... sleeper + sum!!!!!!
Old Nov 10, 2010 | 09:45 AM
Prophecy99's Avatar
this is what I was lookin for. Nice and thanks for the response... i may have to do this.
Old Nov 11, 2010 | 06:42 PM
5 ltr. beater's Avatar
True CAI.
....a true CAI will give the OP the exact opposite of what he is looking for....
Old Nov 11, 2010 | 06:44 PM
fallopian tubes???
Old Nov 11, 2010 | 11:43 PM
CMax03's Avatar
Long tubed intakes seem to boost low and midrange power but suck @ higher rpms due to being to restrictive due to it's length..... most longer tubes make good low/mid range gains and most shorter tubes make better mid/high range gains.....But when a JWT 6" bellmouthed SRI is used in conjunction with the Helmholtz and Oem muffler the lowside is still linear and crisp.....play around with it....you'll see!
Old Nov 12, 2010 | 08:01 AM
T_Behr904's Avatar
Isn't the Helmholtz the resonator box mounted right after the TB? I thought that design was more for a reduction in intake noise rather than airflow. I remember studying the Helmholtz years ago in a science class, I had to Google it to remember what it was exactly.
Old Nov 12, 2010 | 08:20 AM
RKS's Avatar
RKS
LS1
Old Nov 12, 2010 | 08:36 AM
Cant_Get_Ryte's Avatar
Chocolate_Boi_1Der
If you have an auto i would have to say look at a new torque converter. my 3k stall will lay rubber for alot further distance than before lol.
Old Nov 12, 2010 | 09:34 AM
Eirik's Avatar
fallopian tubes???
I'm guessing he's referring to what the OP will be doing immediately after spraying SeaFoam into his woman's uterus.
CMax03: Aren't people insisting in other threads here that the OEM cat is more efficient and less restrictive than the "high-flow" aftermarket variants? Someone suggested that Cattman's is the only one that is actually more free-flowing than stock. Further reading on the matter leads me to strongly suspect that those who feel catalytic converters are some massive, power-leeching piece of ancient technology haven't been informed of how different the modern three-stage cats are compared to their early 70s brethren that everyone seems to be familiar with.
If you have the money, I'd wager that replacing the cat with a NEW OEM cat would yield the same results as putting on a "high-flow" cat. The difference has to come from the fact that one is eight years and 1XX000 miles newer, right?
Can you explain anything else about the nifty "trick" muffler we've got? I've always wondered if Nissan chose components on our cars to aid in performance, even though most posters here seem aggravated that Nissan didn't put cheap 2010 performance technology onto their cars manufactured in the summer of 2001. Oops.
You can't sell a sports sedan without having anything "sports" on it, right? At least something has to be... Oh, wait... Yeah, you totally could.
