AC/Heat not working on low
Noticed this a few weeks ago. When I put the AC on, regardless of it being on hot or cold, "1" doesn't generate any hot or cold air. It sounds like the system kicks on (if at night, lights dim for a split second like usual). Yet, when on 2, 3, or 4, it's perfectly fine. Any ideas as to why this would happen?
Mine did the same thing, then shortly afterward 2 didn't work. Only my 3 and 4 worked and they both sounded like a jet plane. Then3 stopped working and only 4 worked. Then it all died. My friend took it apart and said that I blew a fuse, fried my regulator and fan motor. So 200 dollars later I fixed everything but only me heat and ac work on 4 until I replace the regulator for the other speeds. I was told the regulator cost 75 bucks. Still have to get that.
You don't need to take the glove box out to change the Amplifier/Resistor, as both screw are fully accessible ... now if your going to change the blower motor then you will need to remove the glove box as described.
Remove the 2 screws holding the Amplifier/Resistor, pull out the Amplifier/Resistor and install the new one.
Do you have the manual controls or is your unit a digital display? there is a huge replacement price difference between the two units. Here in Canada from the dealer the manual ac/heat Amplifier/Resistor goes for 55.00 plus taxes and the digital Amplifier/Resistor goes for 148.00 plus taxes
If it's the amplifier/resistor that is causing nothing to happen on the lowest level, I'll just change that (though with my luck, it will be something else)
Hopefully it is just the resistor and it is quite simple to change ... I have had to do mine twice in the past two years ... unfortunately mine is a digital display, the second time I also had to change out the blower motor (which I picked up from the scrap yard for 50.00 bucks)
and no I didn't disconnect the battery it is a simple remove the two screws and unplug that unit and plug in the new one and reconnect the two screws
I can't say for sure as yours would be the manual one, mine looks exactly like the first one. I would assume that yours would be the the standard type ... I would hope one of the guys might chime in on the correct part number for you.
Finkle
Sep 27, 2015 09:53 PM
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
