oem 5.5 navi swap out help
#41
Thieves are idiots. That navi unit isn't worth anything.
You should be able to get an OEM harness from the dealer...if you want to reinstall an OEM Navi.
If you wish to convert to standard: Please note that to date, I have yet to see one person that has confirmed they have fully converted. Yes, my spreadsheet helps but no one has completed it yet.
I can post it if you'd like, but I recommend repairing the wiring and getting the same replacement front end.
#42
Yes theives are idiots... but seeing as how its been impossible to find much less by a stock nav/ac it was kinda ingenius on their part. Not to give the *******/s accolades but I just cant wait. I usually drive my patients around in this car and now they are concerned/scared with all the free wires. Also I already bought the ac climate control head with pigtails. I know over on another forum people did it in a qx4 but the wires are dif. I actually got the auto unit to light up and conrol the fan by pluggin the harnesses that connected to that little gray box (almost identical to the harness for the auto climate control)in the car already only thing it didnt control the heat really and I lost speedo cluster illumination. So im pretty sure its doable. Just need to match wires. If you wouldnt mind posting the spreadsheey id be most grateful or ill pay you whatever you want to do it if your In the ny tristate area. Thanks and I await your reply
#47
Thanks man I actually just got it done about an hr ago. Took me about 4-5 hrs. It def is possible. Just hard to get to the wires unless you remove a lot of stuff. Only thing is the buttons dont light up. And I got you on suspension work. As soon as the moneys right ill be looking for ya
thatcollegestudent
18
10-05-2015 02:29 PM
The Wizard
24
10-01-2015 08:47 PM
