Screwy heater
Old Nov 12, 2010 | 05:12 PM
UConnJack's Avatar
Screwy heater
My heater has not been right for a couple years. Its a manual AC/heater, and for the last couple years, it would only blow cool air unless it was reving or driving. I though low coolant to be the problem, but that has been fine. Then suddenly, this year it works. Actually, it is blowing warm air sometimes when I have the slider to cold. Any ideas? It at least made sense before, that coolant wasn't moving unless the car was at a high RPM. But what would make it change all of a sudden and blow warm air while set to cold?
As a note, it also only blows on 4. I just haven't gotten around to changing the resistor yet.
Old Nov 12, 2010 | 05:16 PM
trooplewis's Avatar
Have you tried burping the system?
Take the radiator cap off, run engine on idle till fully warmed up, continue to run on idle with HEATER ON FULL HOT for 5 minutes, topping off with distilled water as needed.
You may have air pockets in the line, that will fix it.
Old Nov 12, 2010 | 05:28 PM
DennisMik's Avatar
There is a part called the Air Mix Door Motor that moves a "door" that either allows or prevents air from blowing through the heater core. The heater controls in the dash tell the door how much to open. So the heater controls in the dash or the motor could be bad. Pray that it is NOT the motor.
Old Nov 12, 2010 | 05:55 PM
ColtMax's Avatar
I had the same issue.
After replacing the thermostat, outside temp sensor, I found out it was due to a bad radiator cap.
It would let air in the system, so I could never bleed it properly.
Replace your radiator cap and bleed the system as trooplewis proposed.
Old Nov 12, 2010 | 10:30 PM
nelledge's Avatar
"I'm just sayin'..."
Exactly. I waited for about 10 minutes and the heater was still only warm, after changing my radiator. I had to give it several runs up the tach before the system had no air pockets.
howardis
Dec 11, 2019 06:10 PM
dr3am
25
Oct 22, 2015 08:53 PM
RWCreative
Sep 21, 2015 11:01 AM
homeyclaus
Sep 3, 2015 06:15 PM
acw
Aug 7, 2015 04:20 PM
