Those with UDP's with bolts that hold the timing ring...
Old Dec 6, 2010 | 05:01 PM
Tee00Max's Avatar
So I just received my OBX UDP and was looking up some info on here about the installation of UDP's and I ran across where some people had problems with the bolts coming loose that holds the timing ring to the pulley and I was a little worried about installing. I talked to someone that had the exact same pulley and they said to just locktite the screws. Wanted to know of anyone else has had this type setup of a UDP and let me know how they treated the timing ring bolts...
Here are pics of the bolts if you don't know what im talking about
Old Dec 6, 2010 | 06:00 PM
perkman87's Avatar
Lock tite! and prayers
Old Dec 6, 2010 | 06:03 PM
Tee00Max's Avatar
I know!!! im nervous as idk what to install....
Old Dec 6, 2010 | 06:30 PM
Tee00Max's Avatar
also im trying to see if I have the timing ring up there correct, I took the ring off not marking how the ring was placed on the pulley. I think i have them correct because I didn't take the ring off completely. If someone knows how the 3 metal tabs on the timing ring is suppose to go by looking at the notch in the middle of the pulley, let me know. Or will I be able to tell which way the timing ring goes on when I take the stock one off?
Old Dec 7, 2010 | 01:07 PM
Tee00Max's Avatar
?? anyone with any advice??
Old Dec 7, 2010 | 01:11 PM
phatboislim's Avatar
i'm with perk...loctite and torq them down to specs and pray. i've seen people post that said theyve never had issues..ive seen people who said they have..BUT you dont know what they did/didnt do..soo...
Old Dec 7, 2010 | 01:14 PM
Tee00Max's Avatar
well i cant torque them down too much because they are allen screws..So im just going to use the red loctite and tighten them as much as i can and see how it do...
Old Dec 7, 2010 | 01:19 PM
dont ring off the heads of the bolts/allen screws....
Tee00Max's Avatar
o nah i def not gonna do it that hard...that red loctite should do what I need it to do...
Old Dec 7, 2010 | 06:12 PM
Rods03Max619's Avatar
Good Luck with that pulley!!
Old Dec 7, 2010 | 06:13 PM
Tee00Max's Avatar
thnks, im not as nervous anymore for some reason....
Old Dec 7, 2010 | 06:17 PM
Tee00Max's Avatar
I might actually get it mig welded around the screws and then sand it back down smooth to be safe....
Matt93SE
May 24, 2019 02:58 PM
bk2k3max
Sep 17, 2015 09:39 PM
Team STILLEN
Aug 10, 2015 04:29 PM
ZerotoSixty
Aug 6, 2015 04:34 AM
