acceleration run.
Old Dec 26, 2010 | 05:13 PM
  #41
sparks03max's Avatar
DO NOT DO BUSINESS WITH THIS MEMBER - OWES PEOPLE MONEY
Originally Posted by perkman87
I did look into the technosquare ecu and they did seem to say they could set it up for nitrous. I will def retard the timing and get a step colder if I get the nitrous setup . Not going to go higher than 75. It is already a perfect grocery getter. What's funny is the only time I drive her hard is during these silly videos. Never street raced or anything. But I will def be careful.
Thanks Sparks.
If you're sticking with the 75 shot, stock timing is ok. Timing is worth a TON of power on both nitrous and NA, so having them retard it will lose you some power for sure. I ran stock timing with the +2 base from consult when spraying the 75 shot and checked the front plugs after every time I used it and never found signs of detonation. I regularly sprayed with 93 octane. However, I would recommend doing some water/meth injection to go with it for peace of mind without sacrificing power.
The biggest things to remember are a wideband and 1 step colder COPPER plugs. I've heard iridiums are ok, too, but copper is much cheaper. They need to be changed relatively often (20-30k miles depending on how often you spray) but you'll be checking them constantly, anyway.
Tune your SAFC for a perfect N/A ratio, don't worry about nitrous AF until you are dialed in NA. 12.8-13.0 is perfect for most bolton VQ35s (according to many sources, including Jime, my350z tuners, and my own results). Use your fuel jetting to get the right A/F with nitrous. Somewhere around 11.7-12 would be ideal.
DO IT!!!! You will love it... Your transmission might hate it, though.
Old Dec 26, 2010 | 05:16 PM
  #42
321VQ35MAX's Avatar
Sounds good Jon, now get her back on the track and bust a 13 sec pass..
Old Dec 26, 2010 | 05:18 PM
  #43
perkman87's Avatar
I'm at 12.8-13.2. And thanks for the info!
Old Dec 26, 2010 | 05:20 PM
  #44
jowo9's Avatar
Hey Sparks, is 12.8-13.0 AFR ideal even between 3000 and 4500 RPM? I was just tuning w/ my VAFC today and my 4500-6500 range is 12.8-13.2, but my 3000-4500 range is a tad leaner on average (ranges from 12.8-13.6)...
Does a bolt-on VQ35 make the best power at AFR 12.8-13.0 even at 3000-4500 RPM?
Old Dec 26, 2010 | 05:24 PM
  #45
Should I try to get the 3000-4500 RPM range tuned for 12.8-13.0 AFR as well?
Yeah I should have made that more clear.
From 3000-4700 or so, I start at 13.5 and slowly come down towards 13.1 or so. From 5000 up I aim for 12.8.
You don't want it having much variance in any case from 1 moment to the next. The smoother the AF curve, the smoother and higher the power delivery. Nmex can attest to that from his dyno crazy days!
  #46
perkman87's Avatar
Does a bolt-on VQ35 make the best power even at 3000-4500 RPM at a AFR of 12.8-13.0?
We would have to run more timing at that rpm to get it lower with the safc. I have heard of people swapping out 350z injectors to trick the ecu and they can stay at the 12.8 throughout.
Old Dec 26, 2010 | 05:27 PM
  #47
Problem is I can't since I am not on a utec ect.
DE-K injectors >>>>>>> 350z. They are direct dropin, and higher flowrate than the 350z ones (I believe 335cc vs 315cc for Z/02+ max but not 100% sure). I have been using DE-K injectors for a while in mine.
Old Dec 26, 2010 | 05:31 PM
  #48
perkman87's Avatar
Really!!! I have a set sitting at my warehouse. But I do not have a wide band so I would have to make a trip to the dyno....
Old Dec 26, 2010 | 05:34 PM
  #49
A wideband that can interface with your computer to get RPM vs A/F is the greatest investment you can make.
I ended up getting the UTEC Tuner so I can use pretty graphs with UTI
Old Dec 26, 2010 | 05:37 PM
  #50
2002AltimateV6's Avatar
I would have never thought DE-K injectors fit. Huh, I might have to consider that.
I've run a 130 (crank) shot with only -2 timing removed via ConsultII and Meth injection. I actually don't know if it was a 130 shot since I leaned out the fuel jet by about .6 (smaller) to get the A/F from the single digits to 11.5-12.0:1.
But that acceleration run looks pretty good.
http://www.streetfire.net/video/alti...est_643839.htm
Here's mine.
  #51
jowo9's Avatar
Good to know. I'll try to do that. I just am having problems with small lean spikes between 3000 and 4000 RPM. I'm tuning in 200 RPM increments in this area and on certain "100's" that I'm not correcting, I get little spikes. Oh well, I'll get it right eventually...
Old Dec 26, 2010 | 05:41 PM
  #52
It's tough with a SAFC. I had a VAFCII for a while, and even with 24 tuning points it was difficult to get it perfect.
Generally, if you are getting a lean spike 100 rpms after an area, you should add a small amount of fuel to the area that comes directly before it. That worked for me.
Old Dec 26, 2010 | 05:44 PM
  #53
jowo9's Avatar
Yeah, I have a VAFCII, but I chose to do 100rpm increments in the higher rpm areas so as to get that area smooth. It worked wonderfully, but now I have to fiddle with 200rpm increments in the 3000-4200rpm area.
I'll try what you suggested here. The problem with that is that the areas just before the lean spikes are 12.8-13.0, and the lean spikes go up to 13.6 or 13.7.......so I can't really add fuel to the areas before the spikes because they're already getting pretty rich.
Old Dec 26, 2010 | 05:49 PM
  #54
perkman87's Avatar
I wonder if there are windebands that i can run on my Ipad? so i can have pretty graphs.
Old Dec 26, 2010 | 05:50 PM
  #55
Here's mine.
Not bad. What street tires are you running? I'm able to hook pretty consistently in 2nd with the 245/40/18 general exclaims.
Old Dec 26, 2010 | 05:51 PM
  #56
perkman87's Avatar
Here's mine.
great scott! that's impressive.
Old Dec 26, 2010 | 05:55 PM
  #57
Some of the more feature-laden standalone widebands come with software for your laptop (maybe Ipad) and can show A/F VS RPM VS throttle %age if you tap into those inputs.
Many cheapo widebands will now interface with the newer version of UTI for the UTEC and the EU software. The tuner was the only one that UTI would use at the time that I bought mine... otherwise I'd be using a ~200 dollar mainstream wideband.
Old Dec 26, 2010 | 05:58 PM
  #58
Those are Dunlop Direzza DZ101 in 245/40/17. The nitrous requires 275/40/17 NITTO NT05Rs to get all the power down.
I remember back in my VAFC2 days that it had a cross-over point between Hi-VTEC and lo-VTEC maps. Those cross-over points, if set incorrectly, would put "gaps" in between the fuel corrections and cause those spikes. But I don't know if that's the case for the OP.
Old Dec 26, 2010 | 06:00 PM
  #59
jowo9's Avatar
My crossover is between 4600 and 4700 rpms and my AFR is perfect there, so no, that's not the problem... it's in the low half of the LVT map (3000-4200).
Old Dec 26, 2010 | 06:02 PM
  #60
I've been fully hooking for pretty easy 1.8 '60 foots on Hoosier 225/50/15 drag radials... Only had a little practice launching on them, 1.7s are certainly possible. But they are basically slicks with grooves, quite a bit more sticky than the Nittos.
Any track times N/A or spraying?
Old Dec 26, 2010 | 06:06 PM
  #61
Best I've run N/A is 14.2 @ 100MPH with a 2.4 60' on Hoosiers in 275/40/17. Borrowed them off my friend's LS2 GTO. Only made two passes so not enough time to get the hang of it. Bogged both times. I have yet to make a full nitrous run down the track, so no go on that. But this season I'm hoping to go to the track on the fogger setup.
jowo- your best bet is to switch that LVT map over to 100rpm increments. What's the lowest RPM you have it set too?
Old Dec 26, 2010 | 06:11 PM
  #62
perkman87's Avatar
we would be a good match!
Old Dec 26, 2010 | 06:17 PM
  #63
Might need more then a 75 shot since I'm gearing up for a 150+HP direct port setup.
Old Dec 26, 2010 | 06:18 PM
  #64
I think he's saying good match NA.
Perk I'll run you at the track with your 75 shot.... I'll go NA
Old Dec 26, 2010 | 06:22 PM
  #65
perkman87's Avatar
yes good match N/A
and sadly I think you would beat me. auto ratio is so bad when it hits 3rd gear (3rd gear goes to 128)
Old Dec 26, 2010 | 06:23 PM
  #66
Ah! N/A to N/A, yeah. Lol.
I should also mention that 14.2 @ 100 was on the decreased timing and two-step colder plugs gapped at .038. Which isn't too far from stock (.044) but still hurts overall N/A performance. I'm more concerned with the nitrous anyway. As long as the engine is happy on juice, I'm happy. The video isn't a good judge of it's current performance because that was with: SSIM, 3" single exhaust, XS/SSAC headers, 2.5" y-pipe w/ 2.5" magnaflow cat, Technosquare F-Spec ECU Reflash and other various things. So it's gotten considerably slower N/A since I've had to remove the ECU to pursue nitrous.
If I had my way, I would have kept my 4AT Altima (I've owned two, traded in 4AT for 5MT) and built the transmission up. Much easier to work with on juice. Dual-stage, launch off a 30 shot and then the rest right after getting out of the hole. Would need some rather stout reinforcing on the transmission, but much easier to work with then the 5spd.
Old Dec 26, 2010 | 06:26 PM
  #67
perkman87's Avatar
verry verry true!
I ran the same time with 19" and runflats lol. give me radials and its game over, my BBK kinda limits me in wheel setups.
Old Dec 26, 2010 | 06:28 PM
  #68
Yeah those are some pretty tall tires and you're already running with a longer first gear with the 5-speed (even though the 5-speed is superior for the 1/4 mile, I am jealous of your gearing) so that makes an easy situation to bog. If you see the launches in my sig, I'm basically launching off redline and still slipping a little bit to avoid a bog.
With the 75 shot I was able to just launch it hard, let the clutch grab as quickly as possible then floor it for the activation.
I'm in a similar situation on no time to learn with my DRs thus far... Only 6 runs total on them since I bought them. Had 3 different track days get cancelled this season
By the way, Jowo, I find that the stock ECU runs pretty good A/F from around 3000-3500 without much intervention on my part. Maybe you could start tuning more around 3500.
Old Dec 26, 2010 | 06:29 PM
  #69
Yeah, I know how you feel. I'm running SE-R brakes (same thing as the 6th gen BBK) so I'm limited to 17" rims.
Yeah, the tires definitely aren't helping. I just need more seat time! I seem to always base my launches on the track from experience on the street. But they're two very different animals. I can outlaunch RWD cars on the street without much hesitation but on the track.. it will bog. Just annoying. I usually have to remind myself that I'm not on the street when at the track, lol.
Another thing I've thought about is swapping the 4.133 gears from the 6th gen 6spd into the 5spd. It would hurt freeway cruise, but help in acceleration.
Anything new with your nitrous kit? Still at the 75?
Old Dec 26, 2010 | 06:32 PM
  #70
perkman87's Avatar
Yea same here Im running 13" rotors I think 17" is the smallest for me as well.
Old Dec 26, 2010 | 06:33 PM
  #71
yes good match N/A
If you didn't have those BBK fronts, you could run some nice short 23-23.5" tires and make your 3rd gear end around 105-110 and be PERFECT for N/A. Or the 24-24.5" like mine are and be perfect for nitrous. But nooo.... You really needed that reduction in brake fade (since we know the stopping power increase is negligible over stockers with good fluid and pads) and looks. Yeah I give KingJames crap over his BBK all the time, too.
15" wheels in the front > all for drag racing these cars, especially autos. I'd even wish I could fit 14" wheels with a 4AT.
Old Dec 26, 2010 | 06:39 PM
  #72
perkman87's Avatar
hahaha. I get it all the time! But it looks so good!
I wish I had the stockers still I can swap for track and run 15s lol
Old Dec 26, 2010 | 06:41 PM
  #73
perkman87's Avatar
Old Dec 26, 2010 | 07:31 PM
  #74
Fast > big calipers/rotors in the front
Old Dec 26, 2010 | 08:37 PM
  #75
So I went out with the intention of getting a quick 20-110ish acceleration video, but it's cold enough out that I can't get traction below 60 on the highway. So instead, I did a little snow burnout and 'd the limiter a little bit. I was only letting it kiss the stock limiter at 6600, though, the UTEC doesn't extend the limiter until I'm over 60% throttle. (don't need any speeches about the rev limiter, I've hit it many times doing burnouts at the track and missing shifts, it's there for a reason).
Old Dec 26, 2010 | 08:56 PM
  #76
MoncefA33's Avatar
Limiter humping. It's in there.
Old Dec 26, 2010 | 09:00 PM
  #77
Included the humping of 2 different limiters for your enjoyment. I should have used the N2MB rev limiter also for some flames and loud pops. Drats...
Old Dec 26, 2010 | 09:10 PM
  #78
MoncefA33's Avatar
Wish I could shoot fire at a stop. I can only do it while driving.
Old Dec 26, 2010 | 09:11 PM
  #79
Just need a limiter that cuts ignition instead of fuel. The N2MB has a rev limiter function that does that, I just never use it since I'm extending the limiter with the UTEC.
Old Dec 26, 2010 | 09:14 PM
  #80
MoncefA33's Avatar
Well the EU cuts IGN on both two-step and rev limit but it doesn't shoot fire with the two-step.
