Alternator noise?
Alternator noise?
This video is the noise that's been driving me crazy for the past few months.
It sounds like it's definitely the alternator, but my teacher thought it was the p/s pump. I'm imagining it's not because the noise doesn't change when you turn the wheels back and fourth, and the p/s fluid level remains the same.
The noise is clearly coming from the left lower area where all the pulleys are, and you can hear the noise distinctly.
Welp, here's the video
http://s605.photobucket.com/albums/t...t=IMG_0553.mp4
http://s605.photobucket.com/albums/t...t=IMG_0553.mp4Last edited by Spence; Dec 28, 2010 at 01:17 PM.
Sounds like power steering to me. It may be internally bypassing or there may be contaminants in the fluid. Try flushing the PS fluid and put in at least a quart of the Lucas PS Quiet in with the new fluid.
Buy this (about $5 at your local HF store), then you will know for sure. It is a great tool. If the noise is coming from alternator, you can also check the charging voltage. Turn on all electrical loads and see if the charging voltage stays above the battery voltage.
