OEM Radiator
Old Dec 28, 2010 | 07:46 PM
UConnJack's Avatar
OEM Radiator
Does anyone know (I'm sure most of you do) whether the 2000 stock radiator is single or dual core? Got the typical leak at the top of the radiator and I need to replace it ASAP. Was planning on just getting the in-stock single core at AutoZone. Thanks!
Old Dec 28, 2010 | 08:03 PM
TallTom's Avatar
Found this in the GD section. Not sure if it's the same price as the autozone one:
http://forums.maxima.org/group-deals...t-pricing.html
Old Dec 28, 2010 | 09:10 PM
nelledge's Avatar
"I'm just sayin'..."
I've bought two Koyos and silicone hoses from importrp. One for the 4th and one for the 5.5. The KOYOs were perfect fit for both. Plus, no 'Nissan' logo in the plastic(both my originals cracked at that location). Quality products, great service, and fast shipping. Support our vendors.
Edit: Koyo is only like 100 bucks shipped from importrp, is proven, and once again is sold by an .org vendor.
Old Dec 28, 2010 | 09:23 PM
trooplewis's Avatar
To answer your question, they are single core and you can get replacement ones for about $75 on ebay or Amazon. I've replaced both my 4th gen radiators with cheap aftermarket ones, have not had any issues with them since I bought them several years ago.
http://cgi.ebay.com/ebaymotors/NEW-R...Q5fAccessories
I DO NOT recommend silicone hoses, even though they look good. I had the upper radiator hose blow itself off the radiator twice just because it is more slippery than OEM hoses. If you go silicone, be sure to spray some heavy duty hairspray into the ends before connecting so that it will stay put.
Old Dec 28, 2010 | 10:36 PM
CMax03's Avatar
1800 radiator (single core)
Old Dec 29, 2010 | 05:57 AM
nelledge's Avatar
Originally Posted by trooplewis
...I DO NOT recommend silicone hoses, even though they look good. I had the upper radiator hose blow itself off the radiator twice just because it is more slippery than OEM hoses. If you go silicone, be sure to spray some heavy duty hairspray into the ends before connecting so that it will stay put.
I've never understood this phenomena. If the correct application is used with the correct clamps, this shouldn't be a problem. I've never experienced this and I don't know anyone that needed hairspray or any other type of adhesive when using silicone hoses.
Troop: What hoses did you use? Also, what style of clamps? Maybe the ebay radiators don't have the correct neck diameter or length?
Old Dec 29, 2010 | 06:22 AM
phatboislim's Avatar
x3 on single core and i believe, if thats the same people tahts local to me, 1800 radiator is a lifetime replacement and theyre cheap. thats where i got mine from
Old Dec 29, 2010 | 07:32 AM
trooplewis's Avatar
I used the blue silicone ones you can find on ebay (OBX?) I used the original factory hoseclamp, and added a second clamp and torqued the heII out of them after it blew off the first time, still happened again.
Could be the lip on the aftermarket radiator was not as thick as OEM, but when I changed the hose to a regular Autozone hose, it never happened again.
Old Dec 30, 2010 | 02:33 PM
UConnJack's Avatar
Thanks everyone. Got one off ebay for $69 and am installing it this weekend with the help of c-young's writeup. One question though, mine is a MT, so there are no AT coolant lines to attach. Should the connectors on the new radiator be plugged or capped, or would it matter?
Old Dec 30, 2010 | 05:17 PM
nelledge's Avatar
Doesn't matter. Mine was shipped with caps on them so I left as is.
Miket2006
Mar 1, 2021 03:55 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Oct 5, 2015 10:40 AM
atriuum
Sep 28, 2015 01:19 PM
