RSB only works 4 months???
Old Dec 19, 2001 | 11:25 PM
Versace's Avatar
I got my Cattman RSB installed 4 months ago, August 20th i think, and the car felt awsome after it was installed, but im not sure its working anymore... whenever i turn i notice body roll and im not sure it was there before... mabye its i nmy head but i could have sworn the car was stiffer before..... anyone else experience this???
Old Dec 19, 2001 | 11:38 PM
BigDogJonx's Avatar
It might be in your head, or you might just want to get underneath and check the sway bar and check to make sure it is still fitted correctly and the bolts are tight.
Old Dec 19, 2001 | 11:44 PM
Versace's Avatar
Good idea...
Does moving the U bolts inward or outward on the rear axle have any effect on the stiffness at all??
Old Dec 20, 2001 | 04:49 AM
UMD_MaxSE's Avatar
Got Bent?
you probably got used to it.... take the RSB off and then try to do the same things...
Old Dec 20, 2001 | 05:54 AM
Cisco's Avatar
Funny enough, I noticed the same thing with my Stillen RSB. When I checked, the nuts were very loose. Try that first.
GC
Old Dec 20, 2001 | 06:02 AM
acMAX's Avatar
just put in my Addco sway bar
sh*t looks cheap but works awesome.......i sometimes i hear this clunking noise when i hit certain bumps or potholes.
Is this normal? And what exactly is that clunking noise coming from?
Is the sway bar hitting something?
Old Dec 20, 2001 | 07:49 AM
SuDZ's Avatar
Re: just put in my Addco sway bar
Does the bar seem vewry low?
SuDZ
Old Dec 20, 2001 | 10:12 AM
clee130's Avatar
Yes ... check under the passenger side of the RSB.
If you're RSB brackets look anything like this: http://maximaproducts.com/meets/101301/images/rsb1.jpg
http://maximaproducts.com/meets/101301/images/rsb2.jpg
http://maximaproducts.com/meets/101301/images/rsb3.jpg
Then you have to move the bracket in towards the center or over the right as much as possible.
Also read more about it from this thread: http://forums.maxima.org/showthread.php?threadid=71210
Old Dec 20, 2001 | 07:56 PM
irvine78's Avatar
Re: RSB only works 4 months???
i think it's just in your head..but just to make sure it isn't, simply un-do the RSB and then test drive your car. Re-do the RSB and try if it's any different. you can also try stiffer urethane end bushings to make it little bit more flatter.
btw. i got your email, but i didn't have time to send you one. i just came back from Las Vegas and i don't have any picture of my car after the complete bodykit. i'm going to take them soon so i'll try to send you some as soon as i do.
Old Dec 20, 2001 | 09:55 PM
Versace's Avatar
Re: Re: RSB only works 4 months???
Its okay don't worry about it, when ever you get the chance to send them, i appreciate it... my kit should be here monday or wednesday... and i have an appt on thurs to get it put on... pics should be up friday evening.
also does moving the brackets on the RSB toward the OUTSIDE of the car improve the feel of the rsb? Does moving the brackets INWARD lessen the feel of the RSB?
And should i only do this when my car is on a lift or is it okay to move one bracket at a time while my car is on the ground?
Old Dec 21, 2001 | 10:03 AM
Versace's Avatar
Re: Re: just put in my Addco sway bar
Actually by brackets are dented just like these
Old Dec 21, 2001 | 01:42 PM
clee130's Avatar
Re: Re: Re: just put in my Addco sway bar
In that case, like I suggested, move the right bracket in towards the center or out towards the side. When we moved it out towards the side, the next time we checked, it still got bent slightly, but only a little bit.
Old Dec 21, 2001 | 06:37 PM
acMAX's Avatar
Re: Re: Re: Re: just put in my Addco sway bar
should both brackets be moved in towards the center to keep
everything symmetrical?
and once it's moved in towards the center will it effect performance?
Old Dec 22, 2001 | 05:12 AM
wdave's Avatar
Re: Re: Re: Re: Re: just put in my Addco sway bar
You can move only one, no problem. Moving the bracket toward the center of the car will soften the effect slightly, moving them out stiffens it. You can also adjust the trailing arm mounts (though there's brackets etc. in the way) forward is softer, rearward is stiffer, but this isn't huge compared to with and without.
jerrod99_se-l
Aug 27, 2015 08:27 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
KGMtech
Aug 18, 2015 09:21 AM
kenc15
Aug 5, 2015 08:29 AM
