Replacing struts once again, still on OE struts mounts in the rear, worth the $50 to replace or not even worth it? Seems as if I never hear about them causing any issues.
You won't know for sure until you pull them out. Going by what I had read, I ordered new front mounts only when I replaced all struts. Turns out the fronts were fine and the rears were worn.
Quote:
I would do them all as they may go at any time. ALso unless your are going with stockers, you probably want the same brand all around.Originally Posted by bjr
Replacing struts once again, still on OE struts mounts in the rear, worth the $50 to replace or not even worth it? Seems as if I never hear about them causing any issues.Thanks
Quote:
+1 on this advice. Kind of hard to argue against experience. Listen to djfrestyl.Originally Posted by djfrestyl
I've done over 100 Maxima suspensions, and I've only seen one bad rear mount.
