help safcII
Did you make sure the sensor setting is 1 in 1 out? If not, it really messes with the MAF signal and could cause those symptoms. Make sure you initialize your SAFC first (see instruction manual on apexi website...it resets all settings).
alright thanks guys, i knew it wasnt seeing maf, i just left maf wire out for now so it went back to running ok, also the setting under hot wire should be 1 in 1 out thats what it was at before.
yeah well i just put the maf wire back to pcm.. did not go to safc.. a few hours later i reconnected the maf signal to safc and it works fine,
as far as mods-
intake spacers, short intake, vias delete, obx v2's, cattman fast cat and cattman catback for now
as far as mods-
accordingtou
May 27, 2009 08:25 PM
