TunerMax 5th Gen to 5.5 Headlight Conversion Hook-UP Guide & DIY
Old Feb 25, 2011 | 02:38 PM
TunerMaxima3000's Avatar
I'll be Editing this once the DIY is complete. For now I'm only including the Hook-Up Guide portion.
Once this is a complete DIY with Hook-Up guide, It needs to get stickied, so please keep the comments ON TOPIC, and let's get this thing stickied for everyone, Thanks.
I am 98% sure of this set up for ALL years listed, there can be no confusion with my Guide, because it does NOT rely on colour codes. The colour codes change between years so DO NOT rely on them.
You want to hook up according to TERMINALS. The terminal designations are the same for 2000/2001, and for 2002/2003.
This set up WILL work on Canadian OR US models, DRL or not.
Just follow the terminal designations I've provided and you'll be fine.
Here is the Complete hook up guide:
2000/2001 --------------- Headlights ---------------- 2002/2003
Terminal 3 R--------------------------------Terminal 4 R (high beam)
Terminal 3 R--------------------------------Terminal 1 R (low /HID)
Terminal 1 R--------------------------------Terminal 5 R
Terminal 3 L--------------------------------Terminal 4 L
Terminal 3 L--------------------------------Terminal 1 L
Terminal 2 L--------------------------------Terminal 2 L (ground supply low beam)
Terminal 2 R--------------------------------Terminal 2 R (ground supply Low Beam)
Terminal 1 L--------------------------------Terminal 5 L
----------------------Marker/Parking------------------
Terminal 1 (coloured)----------------------Terminal 3 (red/yellow[coloured]) Positive
Terminal 2 (black)-------------------------Terminal 2 (black/yellow[black]) Ground
--------------------------Signals-------------------------
Terminal 3 L (g/b [coloured] +)----------------Terminal 1 L (g/b [coloured] +)
Terminal 2 L (black -) --------------------------Terminal 2 L (black -)
Terminal 3 R (g/y [coloured] +)----------------Terminal 1 R (g/y [coloured] +
Terminal 2 R (black -) --------------------------Terminal 2 R (black -)
These are the relevant power-flow wiring diagrams, for clarification of the above Guide, should you need it:
2000 headlights DRL CANADA:
2000 Headlights USA:
2000 Parking Lamp in Headlight:
2000 Signals in headlamp (same E24/E45 harness as parking):
2003 Headlights DRL Canada:
2003 Headlights USA:
2003 Parking lights in Headlight (same E161/E165 connector as Headlights):
2003 Signal in headlight (different harness from parking lights):
Old Feb 25, 2011 | 02:39 PM
Here is a pic to show you guys what harnesses you need. This is a temporary post until I complete the DIY portion.
The harnesses circled in RED are NOT necessary, they plug into the ballasts, and SHOULD be included with your headlights. If you bought aftermarket headlights with OEM ballasts, you will need them. If you bought aftermarket headlights with aftermarket ballasts, you'll need just the marker light harness (generic, but OEM is recommended).
Note, you WILL NEED bulbs of course, but they are NOT part of the harness, you can purchase them separately (for the noobs that aren't sure), marker light type is 168.
This is what you need for harnesses:
2 - HID harnesses
2 - High Beam Harnesses (Bulb type is 9005)
2 - Signal Harnesses (Bulb type is 7440)
Old Feb 25, 2011 | 02:40 PM
Bookmarked x 2
Bookmarked x3
Old Feb 25, 2011 | 11:44 PM
Nexus67's Avatar
Subscribed.
Dumb question: when you installed did you go directly into the 00-01 harness or did you use the wiring kit from DaveB?
Good job btw
Old Feb 26, 2011 | 05:03 AM
Originally Posted by Nexus67
Subscribed.
Good job btw
Contrary to popular belief, Dave B does not have a 'kit'.
He sells the 6 pigtail harnesses and 2 clips. You can junkyard hunt for those parts. Dave B sells the whole works new for around $55-60 though, not a bad price at all. You need to splice in on the 2000/2001 side regardless.
I used the harnesses off a 2003 (all 6).
EDIT: Just want to note, you can buy the marker light (if needed) and High beam harnesses from any part store, they're generic, OEM IS recommended though, they are a much better harness. The HID harnesses MUST be from the dealer, unless you want to hardwire (not recommended). And the 2 clips can be purchased from the dealer for less than $10 for the pair (hard to believe they're so cheap).
Just something to consider, I hope those overlooked facts don't rob Dave B. of his 'kit' sales, he's a great guy and has amazing deals. I just think it's important to share the knowledge that you don't HAVE to spend that extra money, especially when this swap can cost over $500 before you buy bulbs or harnesses.
Old Feb 26, 2011 | 05:41 PM
Nexus67's Avatar
My saying 'kit' was just a reference. I would figure most folks would know they're harnesses
I definitely wouldn't junkyard hunt for such parts b/c new isn't a wallet-stopper like you said.
Old Mar 12, 2011 | 10:42 AM
steelerfan's Avatar
steelerfan
I'm a newby....just joined..I'd like to go hid on my 2000 gle. If I go the junkyard route, what do I need to take off the car, and what should I buy new from the dealer? Thanks for your help.
Old Mar 12, 2011 | 12:11 PM
Very nice work on searching man. I am hoping to complete the DIY section by the end of next weekend, I'm doing the swap on a friends car, sorry for the delay guys.
I have had a couple guys ask me this already, so in the meantime I will use Post #2 to show you the harnesses you need.
Please scroll back up to that post, if you still have questions feel free to ask.
Old Mar 12, 2011 | 05:50 PM
steelerfan's Avatar
Thanks guys. I appreciate all the help. Just picked up a set of three piece racing hart c-5's with toyo rubber for my max....they should look nice with the light silver blue color.
Old May 8, 2011 | 04:03 AM
sweed88's Avatar
Are these terminal designations from the front of the plugs where you would plug it into the lights or from the back of the plugs where the wires are pinned into the connectors?
Old May 8, 2011 | 07:02 AM
'Male' End viewed 'head-on' or as you said, "front of the plugs"
Old Aug 6, 2011 | 06:31 PM
beefster's Avatar
i tried searching, but not that much luck (probably worded it wrong)
how do you fit the 5.5 headlights on a 5th
i tried for an hour today (had to to take off the hid ballast thing on the bottom)
with no luck
any tips
thanks
Old Aug 7, 2011 | 02:58 PM
might be worth a read.
http://forums.maxima.org/5th-generat...gentlemen.html
They fit they're just a bit of a pain to get in there, even on the 5.5 gen they're a bit of a pain.
Old Sep 7, 2011 | 06:16 PM
cardana24's Avatar
Blown
I am in the middle of this and I am confused on the 02/03 high beam plug. Which terminal is 4 and which is 5, in realation to the way it plugs into the bulb? Since it does not have a release clip like the others I am confused as to which was is up. Can anyone clarify this?
*Also, thanks for doing this write up*
Old Sep 7, 2011 | 07:41 PM
There IS a release clip. Maybe yours are broken?
And if you don't have DRLs, it may not actually matter which way you hook it up. But I advise the way I mentioned.
Old Sep 8, 2011 | 06:05 AM
cardana24's Avatar
Blown
My clips are brand new from DaveB, they don't look to be broken.
So the release clip is pointing "up"? When it's plugged into the high beam bulb the pointy nub will be pointing "up"?
Also, these headlights are new to me....I don't know what DRL stands for
Old Sep 8, 2011 | 07:15 AM
Brl24's Avatar
DRL-daytime running lights
Old Sep 8, 2011 | 10:39 AM
cardana24's Avatar
Blown
Thanks for that
Do you know the answer to my question about the high beam plug...which way is up?
Old Sep 8, 2011 | 03:49 PM
Clip is up. As shown in picture. so if it's disconnected and you're looking at the harness, the clip is on the top, then terminal #4 is on your left.
Old Sep 8, 2011 | 07:03 PM
cardana24's Avatar
Blown
Do the grounds need to be shared? There are enough of them to hook one wire to the other, rather than hooking them all together.
Old Sep 8, 2011 | 07:23 PM
I have no idea what you're asking here.
Old Sep 9, 2011 | 03:00 AM
maxspeed96CT's Avatar
The original VQ...
Damm good info, now the hard part is finding 2k2 headlights for a fair price....
Old Sep 9, 2011 | 03:59 AM
Brl24's Avatar
Haha ya :l
Old Mar 18, 2012 | 08:05 PM
projektshocker's Avatar
I am bringing this thread back up again.. seeking to get some support from members on the board.
I will be ordering this harness to go with the headlight conversion. Is this the correct harness to get?
http://www.nissanpartszone.com/parts...009-5y700.html
Also in process in picking up the headlights this week. Let me know!
Old Mar 19, 2012 | 06:11 AM
I have no idea from that picture or site, and the link you posted only shows a part number.
Left and right are different though if you're getting the OEM ones.
Old Mar 19, 2012 | 06:13 AM
Grand_hustle17's Avatar
Did u get the amp tuner?
Old Jun 27, 2012 | 07:56 PM
Dam itz Lou's Avatar
Hi I just got my maxima 2000 a week ago and looking to do the conversion.
All the info about the conversion is a bit confusing. I'm just getting into maxima's.
From what i've read you need the headlights,wiring harness and the clips.
I see this guy selling a harness that he saids is a plug & play so it doesnt require any splicing.
http://forums.maxima.org/5th-generat...t-5th-gen.html
is this true ?
im planning on getting OEM 02-03 headlights. I'll most likely do the 02-03 bumper later down the road.
Old Jun 28, 2012 | 03:03 PM
is this true ?
If you want something plug and play, that will work. Personally I don't like to see Electrical tape on the connections. I have no idea how that was connected.
Also that will only work on the US car without daytime running lights.
Old Jun 22, 2013 | 11:32 AM
esco115's Avatar
I hate to revive this ****, but I am STUCK!!! I tried this several times 5 dif ways!
Is there any dumber DIY for this crap with good actual images maybe? Or someone has some maybe?
So far I have done it this way, blew a fuse immediately, tried it the cardomain way with the half *** images and blew another fuse... lol
Tried it some other way and well everything works... BUT my park lights are the HIDs... lol
And the actually park light comes on when I turn it to headlights...? wtf!
So I know I have 2 wires wrong just dunno which one it is!
Suggestions anyone?
Old Jun 22, 2013 | 11:44 AM
When looking at the pictures of the harnesses, you are looking at the disconnected end. Not the wire end.
It's really simple, actually.
Old Jun 22, 2013 | 11:51 AM
esco115's Avatar
^Yes I know... lol
But there is something either I am not getting or not doing right either way I know its me obviously... lol
To make sure, When you have it listed as L headlight or R headlight is this as L Pass and R Driver?
Or L Driver and R Pass?
Old Jun 22, 2013 | 02:04 PM
LEFT AND RIGHT directions are always assuming you are sitting in the driver seat.
That makes:
LEFT = DRIVER
RIGHT = PASSENGER
Sorry for that confusion.
Old Jun 22, 2013 | 02:09 PM
esco115's Avatar
Alright, got everything working thanks OP.
Just got one more issue... My driver side works perfect all of it, however, not the same story as the passenger one. Turn on and everything works but once I hit high beams the HID and park light turns off and once I let go everything comes back on like normal... any ideas org? This ONLY happens on the passenger side not driver.
Old Jun 23, 2013 | 03:34 PM
esco115's Avatar
No one?
Old Jun 23, 2013 | 03:50 PM
cjandura's Avatar
Aftermarket hid kit?
Old Jun 23, 2013 | 04:06 PM
esco115's Avatar
No factory
Old Jun 27, 2013 | 07:33 PM
esco115's Avatar
I changed the ballast out and still does the same thing... Anyone? ideas? NO?
Old Jun 27, 2013 | 10:49 PM
Low beam is supposed to shut off when the high beam comes on. That's normal. Unless I"m mis reading
Old Jun 28, 2013 | 09:40 AM
esco115's Avatar
Are you sure? even the park light turns off also when high beam is hit?
Passenger Side - When lights are turned on everything works as it should but once I hit the highbeams the HID and park light turns off and high beam turns on... thats normal? I think not honestly.
Driver Side - When lights are turned on everything works, once I hit highbeam everything stays on with the addition of the highbeam coming on. To me thats normal maybe?
