Radiator Fan Blade Broke Off
I was replacing my radiator tonight and had a brief mental lapse and wound up knocking the fan blade off the motor of my passenger side fan and am wondering if there's a cheap way to reattach it without having to replace the whole fan, which works just fine.
See the pic linked below. You can see the center where there's usually a round metal piece with teeth attached to the fan blade. That metal piece is still on the end of the motor, so the plastic somehow broke.
Any ideas how to re-attach the blade? I've done some searching but haven't found anything similar.
I decided to just attach the metal piece the center using some epoxy I had in the garage. It's not heavy duty stuff, so I'm not sure if it will work or for how long. I set it last night and drove 20 miles into work this morning without an issue. If it detaches, I may try to some more heavy duty epoxy that takes longer to set and see if that works. But a good chance i'll just have to replace that fan.
Spend the $45 and get new fans. The cheap ones are here
http://cgi.ebay.com/ebaymotors/2-10-...Q5fAccessories
And Ebay sells the OEM style ones for $94
Unclejunebug
Apr 2, 2016 05:42 AM
