03 maxima BOSE A/C console lights out
Old Mar 6, 2011 | 05:26 PM
cmd26's Avatar
I kno there is thread on here but i couldnt find it, my gf console control lights r out she bugging me to fix it so ant info or pics wuteva would help.
Old Mar 6, 2011 | 06:13 PM
TunerMaxima3000's Avatar
For a second time, I'll help out.
Search for:
Climate control lights out
I know, makes so much sense, you can't figure out why you didn't think of it right?
Old Mar 6, 2011 | 06:14 PM
TallTom's Avatar
Just replaced mine last week. I have the manual HVAC (Not climate control one) and it takes 3 bulbs.
Bulb part number from Nissan: 27545-1W600
Cost: just under $4 each from the dealer
"How to" on swapping them out:
http://home.comcast.net/~kcmurphy72/i30/HVAC.pdf
Old Mar 7, 2011 | 02:58 PM
zero2sixtyZ's Avatar
You embarrass me.
Probably one of the most well written DIYs on this site I've ever seen.
Old Mar 7, 2011 | 03:36 PM
TallTom's Avatar
I agree. The guy did a helluva job on it.
Old Mar 7, 2011 | 06:09 PM
cmd26's Avatar
Search for:
does this make sense douchebag
thanx talltom
Old Mar 7, 2011 | 06:36 PM
thanx talltom
Wow you really are a complete idiot aren't you, I"m sorry to just call you out like that, but you're going to get lippy with me when I try to help you out? You really don't have a brain do you?
Here, I'll hold your hand:
SEARCH FOR: Climate control lights out
That simple search would have yielded these results:
http://forums.maxima.org/search.php?searchid=1729599
Which clearly show this current thread, and then just below, the very recent (03/04/2011) thread by Gizmo:
http://forums.maxima.org/5th-generat...wont-work.html
In which I went into full detail about how to replace the lights, I even included pretty pictures, you're really going to love it, I didn't colour anything so it may be just out of your age range, but I'm sure if you try to concentrate you'll figure it out.
Because I fear you're as incapable of clicking those links as you were incapable of accepting the Spoon feeding I offered originally in this thread, here is that entire thread I was trying to help you search for:
Originally Posted by Gizm0
Hello,
The lights on the left part of the climate control module stopped working (see circled in red below - front/rear defrost, Auto, Econ, Off, Temp control ****, and air recirculation).
Has anyone ever had this problem and fixed it? If yes, how?
Thanks!
If you're talking about the Illumination portion, there are 3 small bulbs in the ACC unit.
You have to remove the unit, pull it apart and then replacement is simple.
Nissan should have the bulbs you need for a reasonable price, if not, you can try taking one into RadioShack.
Ill post a couple pics for you in a bit.
Yes, these are the one I'm talking about. The lights that are supposed to come one at night when the headlights are turned on so you can see the buttons.
If it's 3 bulbs in the ACC unit, then I'll need to know how to remove it.
Here you go:
you'll See the 4 little screws (you can see one at least in this pic), remove them, then gently pull the faceplate off the back.
Thanks man, but how did you remove the unit from the dash?
Really?
Invest in one of these:
pepboys, autozone, whatever.
one Phillips (star) screw in ashtray, then Use the tool to pry around the shifter, remove shifter trim (you can just slide it out of the way),
Then pry top vent off, remove.
two 10mm head bolts on top, two on bottom, pull assembly out, 3 or 4 Phillips screws into the side of the ACC on each side, slide ACC out and unplug. Then follow photos.
Most people would have said SEARCH.
Next time I may be one of them
Originally Posted by wiseguy55
Wow! Thanks I have this exact same problem!
Thanks for the help!
Originally Posted by MAXXED_816
Anyone know what size these are? I read on here that they are 3mm neowedge, ordered some from superbrightleds website and they seem too small? Maybe 4 or 5 mm?
Originally Posted by Shinjiduo
4mm Neo Wedge don't bother to get them in LED eith as serious hotspotting will be the result. You are better off getting them OEM for $3.00 a pop shipped from http://www.mccarthynissan.com/order-parts/ the part number for them is: 275451W600
Kthxbye
Samedi
Aug 13, 2015 04:05 PM
acw
Aug 13, 2015 12:50 AM
kirkhilles
Aug 8, 2015 10:53 AM
yat70458
Aug 3, 2015 01:16 PM
