How to remove the side line on a maxima 2002 ?
Old Mar 15, 2011 | 07:00 PM
mahanddeem's Avatar
Hi
Mine is faded with areas where there is no line at all....I want to wipe it out completely.......What is the best and cleanest way to do that ?
thanks
Old Mar 23, 2011 | 08:51 PM
026speed's Avatar
Do you mean the pinstripe? If you do.. then use some rubbing compound after you have thoroughly cleaned the area and follow that up with a polish and then a wax to repair any marring that the compound would have made on the surface. If that dosent work then you will need some 2500 or 3000 grit wet sand paper. If you don't know what you are doing its better off leaving it to a pro so you don't burn up the paint. I have a shop in the NYC area where I do things like this. PM me if you need help.
Old Mar 24, 2011 | 09:07 AM
pkrainert's Avatar
Buy one of those rubber wheels that the body shops use. I Think its called a magic eraser? It goes on a drill and you hold it at an angle. I used to have one and used it to take my pin stripes off. I had a 4th gen with the sticker type pin striping and it worked like a charm. I tried tons of other stuff but it was by far the best and easiest thing.
Old Mar 24, 2011 | 09:11 AM
pkrainert's Avatar
This is all I could find. I went to a body shop and they gave me a website but that was about 8 years ago lol. Anyways here is one http://www.google.com/products/catal...d=0CHkQ8wIwCA#
Mine was a yellow color I have no idea what the specs where.
Old Mar 24, 2011 | 09:16 AM
TallTom's Avatar
I'm assuming this is it.
http://compare.ebay.com/like/2707059...=263602_304662
Old Mar 24, 2011 | 09:20 AM
pkrainert's Avatar
Yep that is it!
pkrainert's Avatar
Buy it, it will make the removal a lot easier lol.
Dennis Twohy
Oct 1, 2015 06:01 PM
fastcarny
Aug 12, 2015 03:50 PM
papo99
Aug 9, 2015 07:24 AM
13Maximasv
Aug 7, 2015 10:56 AM
yat70458
Aug 3, 2015 01:16 PM
