Adding heated mirrors to 02. Relay?
Old Mar 18, 2011 | 04:08 PM
cydrive's Avatar
So after an hour long trip a few weeks ago in rain so bad I couldn't really see what was in my side mirrors, I decided to look into adding heated mirrors. I've been researching for a few weeks, ordered a set of heated mirrors (the whole thing) that arrived this week, read the procedure (link below) and I've run into a roadblock. How do you add the relay and get power connected to it?
I definitely don't have the relay in the relay box. Theres a big hole where heated mirror relay is supposed to be. Has anyone done this and had to add the relay?
Procedure I'm using:
http://www.nicoclub.com/archives/5th...e-mirrors.html
Old .org link that is now dead:
http://forums.maxima.org/5th-generat...-question.html
Old Mar 19, 2011 | 10:08 AM
Chris Gregg's Avatar
Get Off My Lawn
Inerested as well. Heated mirrors should be standard equipment!
Old Mar 19, 2011 | 02:01 PM
zzmmrx0xmzz's Avatar
I thought higher trim 5.5 gens come with heated mirrors
Old Mar 19, 2011 | 05:25 PM
cydrive's Avatar
I'm sure the GLE's have them- this one's a base SE, not too many options.
Old Mar 20, 2011 | 07:09 AM
kvk2003max's Avatar
my 03 GLE does not have them. I think they are optional.
Old Mar 20, 2011 | 10:52 AM
cydrive's Avatar
You're right, it looks like it was part of the Meridian package even with the GLE.
http://www.edmunds.com/nissan/maxima/2003/
You would think things like this would be standard, at least on the GLE anyway. But then again, if they were, it would cost a whole lot more and sales would probably have gotten a hit. I'm sure more people, especially up north would love to have this.
Anyway, anyone?
Old Mar 20, 2011 | 12:17 PM
spock's Avatar
Seen this?
http://forums.nicoclub.com/zerothread?id=154634
Old Mar 20, 2011 | 12:59 PM
cydrive's Avatar
Originally Posted by spock
Thanks Spock and yes I have. Its actually the write up I'm using, albeit with pictures. He had the relay in his box so its one thing he didn't have to worry about. I on the other hand, have a big hole in there so I have to get the relay and then get it connected to the heater wires from the mirrors- this is what I'm hoping someone else has done.
Otherwise I have a feeling I'm going to be spending a few days looking at the schematics, playing around with a multimeter and somehow get it figured out. All this in the little time I dont have .
Totally worth it though!
Old Mar 20, 2011 | 08:47 PM
OHH NOES's Avatar
6spd Swapped
To add the relay get power directly from the battery or use the common power wire in the fuse box, run a wire from the rear defroster relay to use as your signal wire to turn the relay on/off when you turn the defroster on/off and run a ground. If you know how relays work you should be able to get it done easily.
Old Mar 21, 2011 | 09:21 AM
cydrive's Avatar
Thanks brother. I think I get the sense of it- i had to add a relay when I swapped my fogs for HID's, sounds similar from what you're saying. I should be able to get to it in another day or two- its the first day of spring so it makes perfect sense its snowing up here and I have no garage to work on it. I'll let you know.
Also if anyone else has additional info, definitely post, its sounds like theres a bit of interest in this so if this works, we might be able to stickie it.
tarun900
19
Dec 20, 2021 06:57 PM
tseng1023
Oct 15, 2015 08:30 AM
jaydot901
Sep 29, 2015 01:18 PM
Max Nu-BE
Sep 28, 2015 10:25 AM
zmcneely13
Sep 26, 2015 02:26 PM
