Anyone know/have a metal aftermarket stereo kit?
Old Mar 21, 2011 | 06:40 AM
phatboislim's Avatar
I have a double din Pioneer in Vanna and i'm trying to see if theres another option besides the plastick one that i have right now...i'm hating seeing it shaking (pause) when the car is shaking (mainly due to bad axles which will be fixed). but i does shake under other circumstances, which arent fresh in my mind.
but i'm trying to see what other possibility is out there, if there are any aside from the plastic mounting one i have right now
Old Mar 21, 2011 | 08:19 AM
MintVQ35's Avatar
I'm not 100% certain I get what you are looking for, you currently have a dash kit that is 100% made of plastic or you actually want the face of it to be metal as well?
I have the plastic faced kit that matches the stock dashboard and I have never seen the thing move or rattle once.
Old Mar 21, 2011 | 08:36 AM
sorry for the confusion. i'm speaking of the brackets for the aftermarket stereo itself...the ones i have are plastic, but i'd like some metal ones like from the factory for the factory deck...you understand what i'm saying now? i also would like to believe thats the reason for my deck sitting so low causing my GXE dash to poke out
Old Mar 21, 2011 | 09:03 AM
MintVQ35's Avatar
Yes you want a metal frame inside of the dash where it mounts, I am quite certain I am using the Metra kit which does not have the metal frame but it fits perfectly snug and flush in my dash without any movement or vibrations. Do you know which kit you have currently or maybe it's that the aftermarket H/U that you have is too deep causing it to be pushed out from the rest of the dash?
Old Mar 21, 2011 | 09:06 AM
im 99% sure i have the metra kit...and its only so much tightening i can do before id crack the plastic mounting piece. maybe ill pull everything apart and try again, but its kinda aggravating ya know..ill take a pic of it before this week is out
Old Mar 21, 2011 | 10:53 AM
Froggmann's Avatar
When I was researching this late last year I did see that a few early headunit swaps used the stock brackets. That should work out for you. Worse comes to worse you could always modify the original brackets to fit your HU.
Old Mar 21, 2011 | 11:15 AM
what year brackets specifically that you are talking about? i hate to modify the old one as JUST IN CASE i'd need it to go back in the car, due to an accident or something, ya know.
Old Mar 21, 2011 | 11:48 AM
MintVQ35's Avatar
You could also try making your own I suppose out of those erector set looking metal strips that are sometimes included in the bracket kits, typically for bracing/securing the back of the HU to the dash.
Old Mar 21, 2011 | 12:07 PM
yea...not a route i'm looking to go..my time is limited, i'm looking for a easy install if you know what i mean
Old Mar 21, 2011 | 01:10 PM
MAXXED_816's Avatar
I have the GXE dash kit with the plastic brackets, its okay :/ I agree they feel kind of flimsy and cheap, but i've never had it a problem shaking or being loose. I tightened down the screws pretty good, the plastic will turn white and flex before it would crack, which it didnt. Although im sure your double din pioneer weighs alot more than the single din and pocket that i have. When i first installed it i used the stock brackets and the h/u stuck out of the dash like 1.5 inches due to where the screw holes were.
Old Mar 21, 2011 | 01:27 PM
yea the HU is heavy, which is a main reason why i'm suspecting that its shaking/weighed down a tad, which is causing my GXE dash to pop out, i'm not a fan of this look/shake at all. i guess ima have to hit up some stereo shops, because i checked ebay and they have what i have
Old Mar 21, 2011 | 02:04 PM
Froggmann's Avatar
I'm pretty sure 00-03 are close to the same. Do you have any junkyards around you? You should be able to pick up a backup set for pretty cheap.
Old Mar 22, 2011 | 04:44 AM
my junkyards around here are crap!! i couldnt find a set of skirts for my 00 i'm hoping that this junkyard im going to in a few wks has something
Old Mar 22, 2011 | 05:13 AM
TunerMaxima3000's Avatar
I'm feeling you on the junkyard situation. It's tough to find anything around here too.
My AVIC D-2 sat too high or too low using the stock mounts in all/two holes I ended up using the stock mount, with only one screw in each side, normally this would have been unacceptable for me, but it's actually perfectly secure.
I have the OEM Metal bracket. I thought all OEM brackets were metal? Have you tried a Metal OEM bracket or just the plastic one?
Mine has 'divets' that sink into the screw location (convex/concave respectively), if your HU accomodates these (Concave bevel in the screw locations) then I'd be opting for that set up, much more secure.
Old Mar 22, 2011 | 05:48 AM
the brackets i have is the aftermarket one, plastic, for my double din...bolts up perfectly...but, its just....not to my taste in how its secured, moving around. not to mention has my GXE dash kicking out a little bit
Old Mar 22, 2011 | 06:39 AM
ChinoX's Avatar
Bring it B*tch!
From: Queenz, nYc CarClub: NYCMAXIMAS.ORG Website: www.ChinoX.net
I've been through about 2 using the metra brackets and metra trim piece the last one is using the original metal ones with the GXE trim piece
Old Mar 22, 2011 | 06:46 AM
hmmm...what deck do you have...the way mine is shaking im afraid its going to break anytime soon. i guess ill see if i can get an extra oem bracket
Old Mar 22, 2011 | 07:44 AM
timelessr1's Avatar
I just installed a Kenwood double din unit, and ended up using the stock metal brackets. If you use the holes on the metal braket that are already there you head unit will stick out. All you have to do it measure where exactly you ned the head unit to be in relation to the heater piece and jsut drill new holes in the metal brackets! this doenst ruin the brackets, but allows you to mount the new aftermarket headuint securely! I'm using the GXE double din dah kit over this and it looks stock!
Old Mar 22, 2011 | 07:49 AM
you have pics of it installed and possibly the holes drilled? ima talk to my 'audio head' friend and we are going to resolve this, i'm sick of the shaking
Old Mar 22, 2011 | 08:30 AM
timelessr1's Avatar
Yeah, i can easily get the pics for you since I'm right in the middle of the instal , and the center console is not fully put together yet! I'll post up some pics tonight of the new holes that were drilled.
Old Mar 22, 2011 | 08:34 AM
alright cool, thanks.
Old Mar 24, 2011 | 08:58 AM
timelessr1's Avatar
Havent been out to the garge to work since its been snowing every other day here on the east coast! should have a picture soon though....
Old Mar 24, 2011 | 09:08 AM
lol thanks man i totally forgot about this i'm trying to fix a vibrating while accelerating problem that i'm having in my max. but whenever you do, post em up at your convinence(sp?)
Old Mar 24, 2011 | 09:57 AM
Axels
Old Apr 27, 2011 | 06:11 PM
timelessr1's Avatar
Ok...i promised to put some pics up of what i ended up doing
As you can see the headunit is almost flush with the front, is super secure and looks pretty slick...
Old Apr 28, 2011 | 04:32 AM
thats hella nice. did you bend those tabs back? i guess i'm going to have to pull out my old brackets and do this number to rid my deck of the 1 2 shake
Old Apr 28, 2011 | 06:28 AM
timelessr1's Avatar
Nope no bending...it did take a while to get the holes in the right spot though.
what i did was use the OEM holes that were available first, and used them to attach the radio. Then installed the bracket/radio back in to the car, and put the OEM bezel back over it. It was sticking out a good 3/4 of an inch. So then i knew i could move the new holes i was going to drill back 3/4 of an inch. Just make sure you keep them on the same plane as the original or else your radio wont be tilted correctly.
There is no shaking with this since its screwed to the metal brackets which are OEM, and those screw into the car
Old Apr 28, 2011 | 06:30 AM
ite cool thanks. i'm going to bribe a friend of mine whose a stereo head to help me do this. one of the small things i'd like to get done
leatherneck
Sep 30, 2015 09:16 PM
sliptap
Sep 30, 2015 05:57 AM
Kyle Lee Cleveland
Sep 28, 2015 09:03 AM
Pied
Sep 26, 2015 03:29 PM
