Idle problem when engine is warm
Old Mar 22, 2011 | 12:03 PM
HDB Audio's Avatar
Ok guys,
So when I start the car for the first time of the day, when the engine is cold, everything is ok, the idle is good. But, after half of hour, if I start the car again, the car start and shut down. I have to push the gas pedal a little bit while I start to run the car and the idle is really low. Also, when I run on the highway, if I push the car hard and hit the clutch pedal, the car shut down. I already try the idle relearn but nothing. the car is running rich because it's smell gas when the engine is hot. Please someone help...
Max
Old Mar 25, 2011 | 01:50 PM
metalpiotr's Avatar
03 Maxima, 6spd
My bet would be on a dirty throttle body. I had a very similar problem.
If you decide to clean it, make sure you're careful and don't move the plate yourself (instead put the ignition to ON, and have someone step on the gas pedal to keep the plate open... or put a brick on it or something).
There is many threads on here about cleaning the throttle body in our cars (which are drive by wire).... and it's a bit of a controversial topic.
Old Mar 25, 2011 | 04:54 PM
Scottwax's Avatar
That's Mr. Detail to you
Read the throttle body thread, follow the directions to the letter and that should solve you problem.
Old Mar 26, 2011 | 07:23 AM
6spdmax's Avatar
Just out of curiosity, are you still running the stock flywheel, or an aluminum aftermarket one? I have the same car and the same issue. I always thought it was because of the lighter flywheel I had installed a couple years ago (not as much momentum), coupled with the fact that the stock spark plugs are still in there after 119K mi. I am changing the plugs next weekend, but I was planning on leaving the TB alone. Maybe I should reconsider...
Old Mar 26, 2011 | 12:10 PM
Scottwax's Avatar
Changing plugs? This should help you:
http://forums.maxima.org/5th-generat...isnt-hard.html
Have the link to the site with a good write-up on changing plugs in that thread. Definitely get the 6th gen rear valve cover when you get the intake manifold gasket.
Old Mar 26, 2011 | 12:49 PM
6spdmax's Avatar
Yes I saw your recent thread. I am driving over to my buddy's house next Saturday and he's going to help me with the job. He recently changed plugs on an 03 Altima VQ35.
But back to the OP, I am still curious if he has an aluminum flywheel.
Old Mar 27, 2011 | 09:59 AM
tom6's Avatar
clean your throttle body, maf and do your Throttle Valve Closed Position Learning
Old Mar 27, 2011 | 04:14 PM
HDB Audio's Avatar
@6spdmax Yes I have a fidanza flywheel but already have this problem before.
I'll try cleaning my throttle body beacause I already try the idle relearning and the throttle body position learning...
thx everybody I'll give you some news ...
Old Apr 11, 2011 | 03:25 PM
HDB Audio's Avatar
thx everyone for the input ! I just made it today! took me about 25 minutes and now the car is running like new, doesnt smell gas anymore !!!
Old Apr 27, 2011 | 02:14 PM
sticky's Avatar
do you have to pull the intake to change plugs
Old Apr 27, 2011 | 04:53 PM
sasha87's Avatar
yes.
MAXSE5SPD
Sep 17, 2022 04:00 AM
sctludwig
Sep 1, 2022 01:32 PM
Pnjboyzz
Sep 4, 2015 09:04 AM
TheMafia
Sep 4, 2015 08:26 AM
A32goldylocks
Sep 2, 2015 06:39 AM
