wont rev past 2500 rpms
Old Mar 31, 2011 | 06:03 AM
  #81
Grand_hustle17's Avatar
Mind posting the link?
Old Mar 31, 2011 | 06:05 AM
  #82
NmexMAX's Avatar
dot dot dot ...
http://forums.maxima.org/5th-generat...-write-up.html
Old Mar 31, 2011 | 06:26 AM
  #83
stokerdevil666's Avatar
check your cat a friend of mine had an cl andd his car went into limp mode we checked everything we could and he adventually put it in the shop the mechanic went through evrything car rotor distributor and finally got down to the cat, the honeycomb had callapsed in clogging up the cat, new cat everything was fixed
Old Mar 31, 2011 | 06:27 AM
  #84
NmexMAX's Avatar
dot dot dot ...
If i know hustle, he has no cats whatsoever.
Old Mar 31, 2011 | 06:46 AM
  #85
So I just tried the APP relearn and nothing.... here is another peice of info that can be useful... if the car is in neutral and just idling, it won't even go to 2500 half the time, if I try to rev it , it will bog and kinda sputter (doesn't cut off).. only when I'm driving it will act normal but don't rev past 2500... if I keep the acc pedal floored it won't even go to 2500, it will try and then bog down to like 500 rpms and sputter its way back up and maybe rev about a couple hundred rpms above idle and bog again
Old Mar 31, 2011 | 07:02 AM
  #86
essential1's Avatar
My axles cry for mercy...
Unhook the vafc. Run the wires back to stock and see what happens.
Old Mar 31, 2011 | 07:24 AM
  #87
datdude20's Avatar
I said the same exact thing
Old Mar 31, 2011 | 07:27 AM
  #88
I never even wired it in lol.... tell ya who ain't messin with it lmao... ill get somebody to do it
Old Mar 31, 2011 | 07:31 AM
  #89
essential1's Avatar
lmao.
Well if the ECU pigtail hasn't been molested yet, pull back the insulation for the MAF wiring and check to make sure all of that is still intact.
Old Mar 31, 2011 | 07:35 AM
  #90
This guy knows me well
Old Mar 31, 2011 | 08:04 AM
  #91
lmao.
Couldn't I just disconnect the middle connector between the VAFC and ECU??, (or is there even a middle connection?
Old Mar 31, 2011 | 08:09 AM
  #92
essential1's Avatar
ok, now I'm confused, is your vafc wired in to the car currently or not?
Old Mar 31, 2011 | 08:39 AM
  #93
Itswired to the car... nvmd I was trippin, I just woke up
Old Mar 31, 2011 | 09:31 AM
  #94
essential1's Avatar
alright. If your VAFC is wired up correctly, there should be a yellow wire and a white wire coming from the vafc harness that is intercepting the MAF wires. Disconnect these and connect the MAF wires back to stock.
This is just to rule out (or in) that the vafc itself is the problem.
Old Apr 1, 2011 | 04:02 AM
  #95
Took a break from the car yesterday, I can see myself going crazy over this stupid issue, I didn't even look at the VAFC setings or anything, hopefully its something as dumb as the maf settings in there (however that changed) ill ry to browse the issue today n tomorrow, I just needed a break, went back to catchin the bus n all
Old Apr 1, 2011 | 03:01 PM
  #96
back at this... again......... checked the VAFC and its working fine
Old Apr 1, 2011 | 05:12 PM
  #97
o.k so i got an ohm meter... i am about to attempt messing witht the TPS signal... my question here is, how and what numbers do i look for with this... lemme see if i even got this straight on how to do it
with the MM, put the red pin to the signal wire (blue iirc)
black pin so a safe ground on the car (tranny for all i care)
i should be getting what reading at idle and what reading at WOT? or do i just adjust for one and the ECU does the rest???... oh another question... what screw do i mess wit to adjust???
Old Apr 1, 2011 | 06:05 PM
  #98
NmexMAX's Avatar
dot dot dot ...
1.x v @ idle, 4.x v @ WOT for TPS. I wouldn't mess with any stop screws or anything.
Old Apr 1, 2011 | 06:19 PM
  #99
how would you adjust it if its wrong???
Old Apr 1, 2011 | 06:20 PM
  #100
NmexMAX's Avatar
dot dot dot ...
You can't, if it's wrong that means either the APPS or TPS is bad.
Old Apr 1, 2011 | 06:29 PM
  #101
mmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm lol... welp, im just gonna blame apps
Old Apr 1, 2011 | 06:31 PM
  #102
NmexMAX's Avatar
dot dot dot ...
Maybe when they were installing the extra pedal the screwed with the APPS stop brick?
Old Apr 1, 2011 | 06:35 PM
  #103
you could be making a funny joke or being serious right now and i wouldnt know lol.... a stop brick???
Old Apr 1, 2011 | 06:39 PM
  #104
NmexMAX's Avatar
dot dot dot ...
Yeah the accelerator pedal stop. There was a recall on it for some models because it was causing the pedal to go too far and then the voltage would deviate from the throttle plate and throw the car into fail safe.
Considering that they were in that area, they might have bumped it or something.
Old Apr 1, 2011 | 06:43 PM
  #105
any recall on JN1DA31D52T201933 ?
Old Apr 1, 2011 | 06:46 PM
  #106
wow i bout the car with 135K miles and got 150K... 15K miles in 2 years... and one long trip to maxus... talk about never driving a car.. 5 oil change in two years lol (even though i do it by date)
Old Apr 1, 2011 | 06:50 PM
  #107
NmexMAX's Avatar
dot dot dot ...
I think you missed the point, obviously your car wasn't on the reacll list because before the swap it was fine. I think maybe they bumped it when isntalling your clutch pedal. Something to look into.
It be nice if you had an OBDII logger so you can compare the TPS and APPS voltages.
Old Apr 1, 2011 | 06:56 PM
  #108
... im just jumpy bro man lls... i take it that the OBDII will say if thats the problem right
Old Apr 1, 2011 | 06:59 PM
  #109
NmexMAX's Avatar
dot dot dot ...
Yeah, you can watch the voltage and compare them. That's how I pinpointed my problem when I threw in the WB and SAFCII. I ended up needing extra grounds on the ECU body because the TPS would get a small spike and then the car would go into limp mode.
Go in and take a look at the gas pedal and see if it looks weird.
Old Apr 1, 2011 | 07:02 PM
  #110
extra grounds on the ECU body? thats a 1st i heard of it
Old Apr 1, 2011 | 07:04 PM
  #111
what you do to ground the ECU???
Old Apr 1, 2011 | 07:07 PM
  #112
NmexMAX's Avatar
dot dot dot ...
It already has a couple ground screws, I just added some more ground wires and a couple of more screws. I think sparks did the same thing.
Old Apr 1, 2011 | 07:09 PM
  #113
lol i dont think my ECU is screwed into anything lol... i think i had taken it out once or twice when i had planned on giving TS a buzz
Old Apr 1, 2011 | 07:16 PM
  #114
NmexMAX's Avatar
dot dot dot ...
Here's where we sorta touched base on it, me and Gemner.
http://forums.maxima.org/5th-generat...ml#post7653736
Old Apr 1, 2011 | 07:23 PM
  #115
believe it or not.. i actually had that problem when i very 1st bought my car... driving then all the sudden no throttle... pulled over turn the car off and then back on and it worked fine... also happened with me n my moms in the car, after that time it somehow never happened again... but would that be the reason for my issue now or can that same problem cause what im going through now?
Old Apr 1, 2011 | 07:24 PM
  #116
NmexMAX's Avatar
dot dot dot ...
Is it doing the same thing or just no revving past 2500?
Old Apr 1, 2011 | 07:32 PM
  #117
now its not revving past 2500... but it doesnt even rev smoothly to 2500 then limits, if im at idle and press the gas pedal it wil sometime immediately bog down to maybe 500 rpms... its really random, it will bog down and sputter all over to throug the rpm, if it sits for long i can get it to rev to a 3k max just once n if i even try to keep it there it will bog down and sputter
Old Apr 1, 2011 | 07:34 PM
  #118
NmexMAX's Avatar
dot dot dot ...
Unplug the MAF and see what it does.
Old Apr 1, 2011 | 07:35 PM
  #119
samething... ive tried it
Old Apr 1, 2011 | 07:39 PM
  #120
ive tried unplugging the MAF (grey connector)... in all honesty it seems as though the revs to 2500 was cleaner with the MAF unplugged
