SE Gauge ?
Old Apr 1, 2011 | 07:35 AM
ilacuss's Avatar
SE Gauges ?
I've searched and can't find anything that helps.
I have a 2002 GLE with traction control and would like to swap in SE gauges. All ebay ones I find don't' seem to have traction control. So if I put these SE gauges in will my TCS light not illuminate but still function?
any thoughts appreciated.
Edit: never mind, looks like there is no way to get the TCS light to come on. http://forums.maxima.org/5th-generat...questions.html
I question though, did SE's come with TCS?
Old Apr 1, 2011 | 08:49 AM
TunerMaxima3000's Avatar
Go to the wreckers and get an SE gauge cluster that HAS traction control.
Or search the online Wrecker directories.
You cannot get used gauge clusters calibrated legally anywhere I'm aware of though, so you will likely have to swap memory chips from your old gauges to retain your mileage.
Old Apr 1, 2011 | 08:51 AM
ilacuss's Avatar
I really don't care about the mileage being accurate....as long as SE's did come withe the TCS option, then I'll just keep waiting until I find one that works. I'm in no rush.
Old Apr 1, 2011 | 09:31 AM
Yes SE`s had TCS.
If you ever get dinged by the DMV or whatever it`s called in the US, you will care that it`s accurate.
OR if you ever want to sell your car, or if it gets in an accident. You should look up the fines and jail time associated with incorrect odometer reading
Old Apr 1, 2011 | 10:07 PM
T.One's Avatar
cant you just put a bulb in where it says slip and TCS off and hook it up? I thought the TCS was a separate module?
Old Apr 2, 2011 | 07:10 AM
MrEous's Avatar
^ Jeff™
I never saw the big deal of the TCS light itself being operable or not. It doesn't affect the TCS system, right?
Old Apr 2, 2011 | 08:40 AM
datsunzcar84's Avatar
How hard is it to swap the milage memory chips?
Old Apr 2, 2011 | 09:34 AM
The theory you both hold is correct, the light IS just an indicator. The TCS module is located under the radio.
What I can't tell you is:
1. If the 'bulb' is included in a gauge cluster that DOENS'T have TCS, and if it is NOT included, I'd like you to know, it's not actually a BULB on your car, it's an LED that is soldered to the circuit board, and you have to remove the needles and gauge faces to replace it or install one.
2. If the wiring is the same on the Gauge cluster, it's not uncommon for the female harness connectors to have a prong 'missing' when the gauges don't have a certain option (ABS, Trac Control, etc, etc.)
If the wiring doesn't exist, then you're into adding wiring also.
I don't know, I haven't put a 5.5 gauge cluster with TCS next to one without, that's the only way you're going to find out if they're different.
I CAN tell you, when a Wrecker looks it up, they want to know if your car has TCS, that's one of the main inquiries, next to auto/manual and Model type.
In short, you're much better off just getting one WITH TCS as I suggested, not worth the headache for most people if they're not compatible.
I haven't done one yet, but I suspect it's not too horrible if you have a good knowledge of circuit board work, and soldering experience on circuit boards. The chip isn't integrated too intense, but it wouldn't be hard to mess it up either
Old Apr 2, 2011 | 10:03 AM
I am kinda bad with soldering so ... I need to practice a bit before I would attempt a swap.
Old Apr 2, 2011 | 10:11 AM
You need a solder-remover as well.
Google, and you-tube, you`ll find some vids of the process
Old Apr 2, 2011 | 10:58 AM
Lol I have watched them a hundred times I have a solder sucker. I couldn't get that to work so I had better success with solder wick. My biggest problem is getting solder to flow. Maybe use better flux than the harbor freight special? Lol
Old Apr 2, 2011 | 11:38 AM
The key with circuit boards is to get LOW FLOW rosin core solder.
Best composition is 63/37, but that can be hard to find.
60/40 will work fine.
Make sure you also get the Thin stuff, for electronic use.
http://en.wikipedia.org/wiki/File:Er...older_Tube.jpg
This will make all the difference. As well, an iron that`s got a fine tip, and power between 25 watt and 100, 50 watt is ideal. Keep the tip clean after each use, and lightly tinned with clean solder
Old Apr 2, 2011 | 12:12 PM
RA121625's Avatar
You learn something new everyday ^
Old Apr 4, 2011 | 08:28 AM
ilacuss's Avatar
I really don't care about the TCS light being on or not but the way the rocker switch is setup you wouldn't be able to tell if it was on or off as there would be no light to indicate it's state.
Old Apr 4, 2011 | 10:15 PM
MrEous's Avatar
^ Jeff™
Turn on car, TCS is auto-on. I dunno, I guess I don't really have a need to switch back and forth that often between startups.
Old Apr 5, 2011 | 06:13 AM
ilacuss's Avatar
Cool, I didn't realize it turned on automatically when starting the car...never really paid attention to it. I've never found a need to turn it off either so would probably never really use the switch.
Old Apr 5, 2011 | 09:51 PM
MrEous's Avatar
^ Jeff™
Just for street racing......
Old Apr 6, 2011 | 06:23 PM
luvlexus101's Avatar
Just don't get an 02. I thought all 03's came with tcs. My SE has it.
Old Apr 6, 2011 | 08:48 PM
I think anyone with the LSD got it, and IIRC, the LSD was only offered on the SE model, so most SE's would have TCS I think.
Old Apr 7, 2011 | 09:19 AM
Eirik's Avatar
LSD != "Traction Control"
"Traction Control" merely uses the brakes to clamp down on a wheel it detects is spinning excessively. A limited slip-diff is way better and way different. http://en.wikipedia.org/wiki/Limited...ial#Geared_LSD
Old Apr 7, 2011 | 11:42 AM
MrEous's Avatar
^ Jeff™
...and HLSD SE gauge wouldn't work on an Auto-Maxima anyway. lol
Old Apr 7, 2011 | 11:54 AM
NmexMAX's Avatar
dot dot dot ...
03 SE AT here, no TCS.
02+LSD AT Maximas in the USA =
Do HLSD SE gauges exist, as in the difference vs non HLSD?
Old Apr 7, 2011 | 03:45 PM
knight_yyz's Avatar
Toolie
I have a gauge cluster from an 03 in front of me from a 6mt, american model. It has the TCS and Slip and AT check on the overlay, but the led's are missing. So I am pretty sure if you get any SE gauge you can solder the led's and it will be ok. Funny thin is it does not have the PRND12 in the center of the overlay
Old Apr 7, 2011 | 03:48 PM
MrEous's Avatar
^ Jeff™
No HLSD specific gauges...but have you seen any AT 5.5gens with HLSD?
...because...
Old Apr 7, 2011 | 04:08 PM
NmexMAX's Avatar
dot dot dot ...
...because...
Probably period, not just the USA... pretty sure we meant the same thing ..
Old Apr 7, 2011 | 06:20 PM
MrEous's Avatar
^ Jeff™
Yeah we both are right. Lol
I was just explaining the HLSD thing I said.
Old Apr 7, 2011 | 08:32 PM
Good to know thanks Ray, I need to stockpile this type of info
Miket2006
Mar 1, 2021 03:55 AM
220k+ A32
18
Sep 22, 2015 11:39 AM
RWCreative
Sep 21, 2015 11:01 AM
kadespraggins
Sep 14, 2015 12:04 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
