crossmember delete?
Old Apr 11, 2011 | 04:44 PM
00Lightsout's Avatar
crossmember delete?
has anyone here permanently removed the crossmember, and welded custom lower motor mounts(torque mounts) to the subframe?
I would imagine that some of you who are run'n a turbo would have done this to gain more room for your piping...
any pix?
Old Apr 11, 2011 | 04:53 PM
OHH NOES's Avatar
6spd Swapped
any pix?
Why would you do that?
Old Apr 11, 2011 | 05:45 PM
Ghost_54's Avatar
I can not remember ever reading any threads where one has deleted the crossmember that holds the two torque mounts
Old Apr 11, 2011 | 06:10 PM
nelledge's Avatar
"I'm just sayin'..."
You would have to cantilever the supports for the mounts which would require greater strength. I really don't think it would be feasible without beefing up the radiator support a bit. Would it be worth the time cost? Advantages>disadvantages???
Old Apr 11, 2011 | 11:11 PM
I personally find this to be an AWESOME idea, even if your VQ is not sport'n a turbo! it could be a significant weight reduction and allows you more room for exhaust fabrication, engine and transmission maintenance
Old Apr 12, 2011 | 05:07 AM
nelledge's Avatar
How so? The crossmember is light without the mounts. I don't think you could save any way by the time you're done fabbing new supports.
Old Apr 12, 2011 | 09:15 AM
OHH NOES's Avatar
6spd Swapped
This would be a good idea if you fabricated your own stuff, it would be way too expensive for such an insignificant benefit. Even with a turbo you don't need to get rid of the crossmember, I still have mine.
Old Apr 12, 2011 | 11:49 AM
there is no neeeed to remove it...it seems more of a personal pref.
I was surprised to see how low this Max owner put their turbo...at the bottom of the radiator!! why?
Old Apr 12, 2011 | 02:51 PM
OHH NOES's Avatar
6spd Swapped
Less piping. It's actually a nice setup.
Old Apr 12, 2011 | 03:09 PM
oohhh I understand...less distance for the air to travel = quicker spool and dump!?
KabirUTA13
19
Oct 17, 2015 02:15 AM
homeofbacon
Sep 23, 2015 07:17 PM
Slamrod
Sep 3, 2015 07:38 PM
mpbclutch33
Sep 1, 2015 09:24 AM
Maximeltman
Aug 31, 2015 01:01 PM
