2k maxima weapon-r install issues
Old Apr 11, 2011 | 05:39 PM
rbellucci's Avatar
Ok, i've done injen, i've done airraid, i've done AEM but i'm having an issue with this install. I've got this thing in, but i'm having an issue with hooking up the second hose. Heres the install notes, tell me what i'm doing wrong
http://www.weapon-r.com/files/manuals/304-113-101.PDF
Old Apr 11, 2011 | 05:59 PM
Stormzusmc's Avatar
ok....be more specific on what you're failing to do besides ask for help...
Old Apr 11, 2011 | 07:01 PM
schmellyfart's Avatar
Its hard to tell you what you are doing wrong when you aren't telling us what you are doing.
Old Apr 11, 2011 | 07:05 PM
rbellucci's Avatar
9 Install the supplied 10mm hose onto the intake pipe and to the air recirculator valve.
I can't find where this hose is suppose to conncet
I found the one that goes to the valve cover, and the pvc valve
The 1 out of three hose outlets on the weapon r intake setup are differnet then what is stock, I connected the one that goes to the value cover, I connected the small skinny hose but I I have one that is a large connect that I still need to connect that I can't find a home for. If you look at the directions that I linked to the top of the page you will see. I will take a pic in a little bit.
Old Apr 12, 2011 | 10:19 AM
NmexMAX's Avatar
dot dot dot ...
IACV anyone>?
Old Apr 12, 2011 | 02:50 PM
rbellucci's Avatar
UPDATE! I figured it out. I had to use OEM plumbing with the weapon r
Old Apr 30, 2011 | 09:32 AM
Legendman's Avatar
post some pics of your completed install..
Iam thinking of getting either the Injen or Weapon R..
Thanks!
Old Apr 30, 2011 | 05:16 PM
OnOiShNo0dl3Z's Avatar
^Legendman, I might be getting rid of my injen soon if you're looking to get one. PM me if interested
Finkle
Sep 27, 2015 09:53 PM
Team STILLEN
Aug 10, 2015 04:29 PM
kirkhilles
Aug 8, 2015 10:53 AM
MikesChevelle
Aug 6, 2015 11:36 AM
