climate control backlights - just died
Old Apr 11, 2011 | 08:22 PM
syne164's Avatar
I have a 2001 AE maxima only two backlights on my automatic climate control work how do i fix that?
Old Apr 11, 2011 | 09:23 PM
shaks's Avatar
you could buy the incandescent bulbs from dealer - those are direct replacement (search around here for part number) or do an LED mod
up to you
almost forgot - you could try to slightly hit the climate control in lower left corner (next to the temperature ****)- my lights come up sometimes after 2-3 tries . I'm about to do an LED mod
Old Apr 11, 2011 | 09:45 PM
syne164's Avatar
ok tell me more about the led mods i might be interested on doing that>> thx
Old Apr 12, 2011 | 01:50 PM
syne164's Avatar
where can i change the bulbs where can i get the led mods for the automatic temperature climate?
Old Apr 12, 2011 | 05:06 PM
cjandura's Avatar
http://forums.maxima.org/5th-generat...installed.html
Old Apr 12, 2011 | 05:47 PM
TallTom's Avatar
I recently replaced mine with OEM bulbs. was pretty easy job.
three bulbs at $4 each.
Old Apr 12, 2011 | 06:19 PM
foodmanry's Avatar
Da Roller Coaster!
Yes, easy to replace. Only takes about 30 minutes or so.
Old Apr 12, 2011 | 06:27 PM
syne164's Avatar
how many bulbs do i need to change on my automatic climate control looking on getting the led neo4 bulbs?
Old Apr 12, 2011 | 06:45 PM
foodmanry's Avatar
Da Roller Coaster!
Don't remember for sure...you can always take it apart to see and leave it apart. IIRC there is one bulb for each button.
Old Apr 12, 2011 | 06:50 PM
TallTom's Avatar
Manual one has 3 bulbs. Can't speak for the Auto climate one.
Old Apr 12, 2011 | 07:47 PM
Montego Murph's Avatar
Here, check out this little gem.
Written by yours truly
http://home.comcast.net/~kcmurphy72/i30/HVAC.pdf
Old Apr 12, 2011 | 07:53 PM
TallTom's Avatar
Thanks. I used that PDF to swap out my bulbs. Was one of the better How To's written.
Old Apr 12, 2011 | 07:54 PM
TunerMaxima3000's Avatar
They are all the same - 3 bulbs.
Old Apr 15, 2011 | 09:38 AM
syne164's Avatar
2001 ae maxima window switches
i wanna also change the bulbs in the front & rear window switches what led bulb do i need and how many for the front..
Old Apr 15, 2011 | 09:45 AM
They are a 3mm LED in the passenger and rear positions.
The Master switch is a circuit board with very small SMDs. You can replace them with SMD's or 3mm LEDs, the 3mm LEDs are tricky to fit in, expecially with a resistor (necessary)
I'm not aware of any place that sells them, you can try the dealer but that will only give you a stock replacement, and I assume you want to change them to a different colour or brighten them, because I've never heard of stock LED's burning out, ever.
I can do the full window switch conversion for 2000-2003 for only $90 if you're interested.
tarun900
19
Dec 20, 2021 06:57 PM
gavin68
Sep 18, 2021 12:36 PM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
