New motor, first time build
Old Apr 19, 2011 | 10:57 AM
colin_SE's Avatar
So my buddy works at a dealership and is going to school somewhere for automotives (can't remember) but long story short, I am buring like 3 qts of oil in 2k miles and need to do something about it. He has a vq35 with a spun bearing at the shop that I can have for free and we are gonna rebuild it and do a swap. I have never done anything with the bottom end of a motor and he is in the middle of learning how now but together we are gonna make this work. I am planning on using everything stock in the bottom end with better rings to stop oil consumption and add some cams while we got it out of the car.
We should be starting next week. What you guys think? The way I see it, free motor, I cant lose. lol
Old Apr 19, 2011 | 11:16 AM
pkrainert's Avatar
Do you have any idea how much it is going to cost you to rebuild? I like the thought of rebuilding becuase you know everything is going to be ok ( if you know what you are doing and take your time) vs. a replacement that could have any number of issues. I just don't know about the cost for replacement parts.
Also what do you plan on changing out? You may want to change stuff like the water pump and whatever else is going to be a PITA once it's actually in the car.
Old Apr 19, 2011 | 11:31 AM
colin_SE's Avatar
Yes, I know what it will cost and I have the funds. We are going to take our time on it, theres no rush. I will use what ever parts are there and keep the rest as replacements
Old Apr 19, 2011 | 11:38 AM
NmexMAX's Avatar
dot dot dot ...
What will it cost?
What rings are you going with?
What cams are you going with?
Will you be documenting as you go along with updates and pictures? This would be nice so we can see and perhaps you and he can determine why yours is such an oil burner. It's probably the rings, but still, be nice to know/reinforce the fact.
Since you're down there, will you be replacing the rod bolts? Seems like a good idea if you're upgrading cams.
What is the build date & mileage of your car?
Old Apr 19, 2011 | 12:34 PM
colin_SE's Avatar
Not sure yet but I will be when I see what I'm working with. Haven't looked into rings yet and IF I do cams they will be mild, nothing crazy. I most likly will be replacing rod bolts as well as anything else that needs/could use replacing. I'm starting when ever I get the motor (next week) and I got 80k miles.
Old Apr 19, 2011 | 01:05 PM
pkrainert's Avatar
You are or are not sure how much it will cost? I am just wondering for future reference if I ever come down this road.
Old Apr 19, 2011 | 01:47 PM
Scottwax's Avatar
That's Mr. Detail to you
Plan out exactly what you want to do and price it out now. Also talk to a couple machine shops to find out what kind of experience they have with Nissan motors.
Rebuilding your own engine can be a very rewarding experience, built a .030 over 350 for my old Chevelle. Take your time putting it back together, make sure you check all your clearances and you should end up with a decent motor.
Old Apr 19, 2011 | 03:23 PM
tdabboud's Avatar
damn man your def moving along quickly.
You certainly have a great opportunity ahead of you, I am sure your gonna plan it all out and what not so more power to you! I cant wait to see some results.
Do you have any idea of particular parts your gonna use or upgrade?
I would def love to give you a hand if you need it.
I started planning a build as well and still have the parts list, prices, and everything but never pulled the trigger. So I am def looking forward to this
Old Apr 19, 2011 | 03:31 PM
colin_SE's Avatar
Well I am planning to keep the head all stock just clean it till it looks new. I will probably be keeping stock pistons with eagle rods with new bearings and crank. Along with that it will have a light weight crank pulley and flywheel. It should run about a grand. I lucked out with the free motor. I will post pics of the progress
Old Apr 19, 2011 | 06:24 PM
bds1304's Avatar
if ur were goin to go into it, i would atleast find a set good set of cams and port the heads. everything else i agree with so far
Old Apr 19, 2011 | 07:28 PM
spock's Avatar
Rod bearing or crank bearing spun? That could make a lot of difference.
Old Apr 19, 2011 | 09:29 PM
colin_SE's Avatar
Rod bearing. I'm still iffy on the cams. I know its a good idea but thats more money. The whole purpose of this is to have a motor that stops burning crazy oil and with some lighter parts and super clean internals I should gain some more power.
Old Apr 19, 2011 | 10:12 PM
Scottwax's Avatar
I'd look into doing some headwork, at the very least, match porting everything.
Old Apr 20, 2011 | 07:42 AM
colin_SE's Avatar
I may. I wanna have the motor apart and in front of me to see what I got going, then I'll go from there.
Old Apr 20, 2011 | 03:44 PM
colin_SE's Avatar
So I sat down and made a list of parts that I will use (depending on what I need) and their prices. Here it is:
Rods $470 http://cgi.ebay.com/ebaymotors/Eagle...Q5fAccessories
Crank $275 http://cgi.ebay.com/ebaymotors/VQ35D...Q5fAccessories
Crank bearings $108 http://cgi.ebay.com/ebaymotors/ACL-R...Q5fAccessories
Rod bearings $110 http://cgi.ebay.com/ebaymotors/ACL-R...Q5fAccessories
Head studs $193 http://cgi.ebay.com/ebaymotors/ARP-H...Q5fAccessories
Head and all other gaskets $81 http://cgi.ebay.com/ebaymotors/Nissa...Q5fAccessories
Crank pulley $152 http://cgi.ebay.com/ebaymotors/Ralco...Q5fAccessories
Flywheel $469 http://cgi.ebay.com/ebaymotors/Fidan...Q5fAccessories
Rear main seal $35 http://cgi.ebay.com/ebaymotors/OEM-N...Q5fAccessories
Rings $73 http://cgi.ebay.com/ebaymotors/Pisto...Q5fAccessories
Not sure about this last thing I found. I prob wont use it just because the parts are most likely no name. It would only save me like $30 anyway.
Full set $365 http://cgi.ebay.com/ebaymotors/Re-Ri...Q5fAccessories
Anything I'm missing or could also use?
Old Apr 20, 2011 | 06:55 PM
spock's Avatar
Have you researched the manufacturers from all these Ebay parts?
Old Apr 21, 2011 | 07:41 AM
colin_SE's Avatar
Thet aren't all ebay parts. Most of them are name brands being sold on ebay. I'm not going cheap on this. Did you even open the links to see?
Old Apr 21, 2011 | 09:48 AM
Rods03Max619's Avatar
Good Luck on the build, and Damn only 80,000 miles and burning that much oil my engine died out at a little under 153 k said it was a Rod bearing or the seals or something didnt want to pay all that labor so I just got a 04 Engine....but if I was you I would check into the port matching.....that what my friend was going to bust for me but all my engine problems came at the wrong time....but good luck on your overhaul....engine build.
Old Apr 21, 2011 | 04:23 PM
colin_SE's Avatar
Thankyou. Yeaa idk why my motor is doing so bad with such little miles. Like I said once the motor Is apart and I se what I need then ill see what I'm going to do
Old Apr 21, 2011 | 08:00 PM
L36's Avatar
L36
Good luck, Ive rebuilt my Mazda 626 2001 motor and transmission, took a lot of my time but the car ran so well afterwards. Not to mention the superior clutches that i used in the AT, made it shift silky smooth with synthetic ATF.
Its all about experience.
Old Apr 21, 2011 | 08:09 PM
spock's Avatar
I opened the links. It's not my build. Drive on.
Old Apr 22, 2011 | 07:34 AM
MintVQ35's Avatar
$470 for a flywheel are you kidding me? +15hp...
Old Apr 22, 2011 | 07:55 AM
colin_SE's Avatar
I didn't say I'm going to buy these for sure. I just made a list of things I may need/want.
I will try to find better prices and other brands when I have the time.
Old Apr 22, 2011 | 08:30 AM
NmexMAX's Avatar
dot dot dot ...
Extended revs to warrant new engine hardware?
Old Apr 22, 2011 | 04:51 PM
colin_SE's Avatar
No. Keeping that the same for now. Maybe later on down the road if I get cams
Old Apr 23, 2011 | 06:23 AM
Eirik's Avatar
I thought you were just going to fix the spun-bearing motor, but you're going to fuse the two engines together? I got kind of lost, but engine rebuilds are pimp, so I'll throw useless encouragement for the project in there, too.
Old Apr 23, 2011 | 09:01 AM
colin_SE's Avatar
No, you were right. I'm going to fix the bottom end of the "new" motor and put in some better parts
Just got dropped off. Can't wait to start takin it apart tonight!!
Old Jul 14, 2011 | 08:59 PM
marky3320's Avatar
bump. How's the progress on the engine?
Old Jul 15, 2011 | 02:08 PM
NmexMAX's Avatar
dot dot dot ...
Pretty sure he's trying to sell everything.
Old Jul 15, 2011 | 02:19 PM
ranmas2004's Avatar
If I were you, if money wasnt a big deal, I would stroke the engine to 4.1L with a stroker kit...while you got the thing out and all....go all out....why put stock stuff back in when you have the opportunity to really power up the VQ? I'm planning on doing that anyway.....
Cotozic
Jun 28, 2017 08:01 PM
vingodine
45
May 21, 2016 12:46 PM
FlaMark
25
Aug 28, 2015 10:15 AM
