Removing ECU
Old Jul 15, 2011 | 03:24 PM
FERN's Avatar
Removing ECU
What is the easiest way to remove the ECU. Having a very hard time and wasted around 3 hours wrestling with it.
Old Jul 15, 2011 | 03:34 PM
NmexMAX's Avatar
dot dot dot ...
There's a harness that you need to unbolt, and there's also an 8 or 10mm bolt on the harness itself that connects the ECU to the harness.
Old Jul 15, 2011 | 03:59 PM
FERN's Avatar
I took off the two 10mm bolts to the harness but it still wont budge. I removed three 8mm bolts, two in the front and one on the back. Is there another in the rear. If there is, I cant see it and its really really tight back there with all the looms tied up back there.
Old Jul 15, 2011 | 04:03 PM
NmexMAX's Avatar
dot dot dot ...
Pull the clip the other way, sort of a ratcheting type of feature.
Old Jul 15, 2011 | 04:10 PM
FERN's Avatar
I will try that. Thanks Nmex
my03maxima
Jul 28, 2024 07:40 AM
gigabyte
Jan 6, 2017 06:05 PM
RealityCheck
Oct 2, 2015 06:34 PM
jaydot901
Sep 29, 2015 01:18 PM
BLACKKILA.GTR
Sep 29, 2015 11:23 AM
