BC Coilovers installed
Old Apr 21, 2011 | 10:59 AM
sunysb83's Avatar
Just got my BC Coilovers done this morning, so far, looks good and it has a very good range of height adjustment. The car is about 25.5 inch from ground to fender all around, but still need to adjust the height again, it is not all even. Dampening set at 10 all around, and so far, the ride is pretty great, not harsh at all.
Here are some pics:
Have about 5.5 inch of ground clearance, just worry about scrapping now, I dare not go any lower here in NYC, may go back up a quarter of inch. Just curious as to how low other people are running with their coilover setup.
Old Apr 21, 2011 | 11:24 AM
mrjamaica98mx's Avatar
nice drop love that color
Old Apr 21, 2011 | 11:27 AM
phatboislim's Avatar
LOVE mine!!! you have any vibrations yet? lol
Old Apr 21, 2011 | 11:49 AM
03VQMAX's Avatar
lol ^ yet? Gosh I hope mine don't vibrate when I install them next week. To the op looks clean. The dampening at 10 is from left to right or right to left? I know I've read the manual couple times still don't get it.
Old Apr 21, 2011 | 11:50 AM
lol if you lower it enough, the axles will bind and youll have vibration at acceleration...i just raised mine enough to deal w/ it.
Old Apr 21, 2011 | 11:54 AM
azdevils013's Avatar
I don't have any vibration with mine. Guess I'm not low enough?
Old Apr 21, 2011 | 12:03 PM
probably not...i think i'm 1/2" from being rid of vibration during acceleration...tell you teh truth, i really think i shouldnt have gotten an alignment...i didnt get any vibration until i got an alignment
Old Apr 21, 2011 | 12:09 PM
sunysb83's Avatar
Only driven about 4 miles on them so far on pretty smooth streets, no vibration or any noise on them that I noticed yet, haven't taken it up to highway speeds, the BQE will be the real test tomorrow, haha, I don't think I'm that low, still have a one finger gap about, really don't wanna bust an axle or my oil pan or anything.
To set the dampening, turn it all the way to the right which is the hard setting, and that is set at 0. Each turn back counterclockwise is 1 level towards soft, so like for me, I turned it back 10 clicks.
Gonna do some more height and dampening adjustment before I get a wheel alignment.
Old Apr 21, 2011 | 12:11 PM
HotshotVQ35's Avatar
Old Apr 21, 2011 | 12:43 PM
TallTom's Avatar
Looks great and I love the color.
Offtopic question: How did you mount your front plate like that? Homemade bracket or JDM kit? I will be moving to NYC in the near future and I am dreading on drilling holes in my front bumper (no front plates here in PA).
Old Apr 21, 2011 | 12:44 PM
nishfish871's Avatar
Looks like everyone is jumping on BC coilovers now! I have to raise mine asap cause it is binding like crazy. Its very tempting to go low, but my stock exhaust is all beat up now and everything else under the car.
Old Apr 21, 2011 | 01:07 PM
MyMommaBiscuits's Avatar
Looks nice!! Afta u take it on da BQE, hit us back n tell us about da handling. I got mine a few weeks ago, just too Damn lazy!!
Old Apr 21, 2011 | 01:14 PM
321VQ35MAX's Avatar
I need/want some coilovers now too
Old Apr 21, 2011 | 02:10 PM
Rods03Max619's Avatar
Looks good wish I had some and the ride looks GOOD to even with fish bowling it..
Old Apr 21, 2011 | 02:17 PM
ffcbairn's Avatar
Anyone know what the minimum drop is?
Sunysb: Is 10 the softest ride? How does that feel compared to stock setup?
Old Apr 21, 2011 | 04:58 PM
30 is the softest ride, 0 is the stiffest.
Old Apr 21, 2011 | 05:36 PM
sunysb83's Avatar
Adjusted the height and kinda repositioned my license plate...
These can drop a lot lower, not sure how low, and it can go higher than stock and really give u a 4x4 look.
Old Apr 22, 2011 | 04:42 AM
yea you shouldnt have any binding at that height you are good to go. looks good, love that blue
Old Apr 22, 2011 | 08:18 AM
Like where u put that plate...
Old Apr 23, 2011 | 06:30 PM
sunysb83's Avatar
Uh, I think I may have a problem, the coilovers might have been installed incorrectly in the front, the camber plates are suppose to be parallel with the front of the car and not at an angle right? I'll get a pic up tomorrow.
I remember my mechanic had a hard time trying to get it aligned when he was installing it and the coilovers only fitted in with the camber plates facing at an angle outward. The L is on the L and the R on the R though.
Old Apr 23, 2011 | 06:51 PM
03VQMAX's Avatar
It should be the standard sides. R Passenger Side and L Drivers. But keep us updated, I'm installing mine next week and I'd definitely would like to know if yours are on wrong or not.
Old Apr 24, 2011 | 06:33 AM
They are suppose to be straight, ill snap a pic of what it looks like later today.
Old Apr 24, 2011 | 06:45 AM
bootiesan's Avatar
BC's
Hey SunysB83 sorry to hear this has happened again. Don't hear about it much but I am going to send a note to my source and tell him it happened again. I love these coil overs, have have very good luck with them so far. I got mine the same way, figured out the camber plates were on the wrong side. They go on the opposite side. if you just swap them and they will be correct, at least that was my problem. Sounds exactly what happened to me. Let me know. Take care.
Old Apr 24, 2011 | 07:24 AM
01SilverMaxima's Avatar
^^Ya same here. Had to swap the camber plates from the left to right and vice versa. Sucks u already installed them, u have to take em off
To swap the plates.
Old Apr 24, 2011 | 12:44 PM
McSteve's Avatar
I had the same problem on mine, I did notice it before installing tho and swapped em.
Old Apr 25, 2011 | 05:09 PM
sunysb83's Avatar
Ya, wish I knew better, so they're installed like this so far...
What's the correct way to fix this? Remove the camber plates from top and swap L to R, or can I just take the whole assembly and switch sides and then just unscrew the bottom part and switch it around?
Old Apr 25, 2011 | 05:52 PM
03VQMAX's Avatar
I was thinking bout swapping sides, but I haven't opened my box again to check them out to see if they are like yours, but they definitely look wrong according to the pics. I hope the sides are swappable. But I'd wait for someone else that has experience with them handle this.
Old Apr 26, 2011 | 12:43 PM
McSteve's Avatar
In order to fix it you'll have to pull both coilovers off, and then remove the allen screws and just swap the camber plates. Once mounted the slots are supposed to be pointing straight left-right instead of diagonally as they are now.
Old Apr 26, 2011 | 01:10 PM
lol oh wow..this is eye opening...mine are assembled wrong as well..i just assumed the person i bought from hd them right...having the camber plates wrong can cause what issues?
Old Apr 26, 2011 | 01:15 PM
McSteve's Avatar
causes that you can't get the alignment right i guess
Old Apr 26, 2011 | 01:19 PM
i got it aligned before...ill note as well...as soon as i got it aligned, my car started vibrating..makes me wish i didnt get an alignment
Old Apr 27, 2011 | 09:58 AM
Good to know, I'm installing my tomorrow, along with a new right axle...
Old Apr 27, 2011 | 01:09 PM
03VQMAX's Avatar
Sorry to thread jack sunysb83, So is this right or wrong? Or do they have to be on the vehicle to tell?.
Old Apr 27, 2011 | 01:14 PM
i want to commit adultery with those, they look so beautiful...btw...what does it say on teh strut itself as far as left or right? do they match to what it says on the camber plate
Old Apr 27, 2011 | 01:17 PM
Old Apr 27, 2011 | 01:19 PM
Old Apr 27, 2011 | 02:55 PM
03VQMAX's Avatar
Oh yea they do match, I thought the camber plate was the only indication, I see where it says FL & FR. So I should be good to go. Thanks
Old Apr 27, 2011 | 03:03 PM
im pretty sure to get them to install right you need to switch em. They need to be left camber plate on right housing and vice versa. Thats what me and several others had to do. GLWI
Old Apr 27, 2011 | 04:02 PM
sunysb83's Avatar
Hopefully I can get it fixed correctly this weekend, so just remove the 4 allen nuts I can remove the whole camber upper mount, correct? I do not need to remove or compress the spring right?
Mine said the correct sides on the top and stickers too and apparently, it still did not fit correctly. Once you have your old suspension removed, just put in the coilover and see if it aligns correctly with the three top bolts, if not, guess you know now to switch em.
Old Apr 27, 2011 | 08:09 PM
Maximized2000's Avatar
Hmmm...I looked at mine and it didnt look right as well out the box. However, I just spun the camber plate up top to make the slots go left to right, wonder if that did the trick? Wont know I guess till its installed.
Here it is now:
