subwoofer and replacement problems
Old May 5, 2011 | 11:27 PM
xshadow715's Avatar
Recently my stock bose subwoofer stopped working. so I got my hands on a working one and i decided instead of taking evertything off i would just disconnect the cord and connect it to the new subwoofer. when i did that it didnt work... now im confused does that mean the subwoofer is not that problem? what else could it be?
Old May 6, 2011 | 09:12 AM
Andy2000max's Avatar
Search the forum for Bose subwoofer cutout problem. Also, check your fuse under the hood.
Old May 6, 2011 | 09:22 AM
DennisMik's Avatar
This. It is a 15 amp fuse - # 67 - in the fuses by the battery.
Old May 6, 2011 | 11:07 AM
xshadow715's Avatar
where is #67? i found speaker and audio fuses but no amp?
Old May 6, 2011 | 11:47 AM
djfrestyl's Avatar
Suspension Yoda
In the fusebox under the hood near the battery.
Old May 6, 2011 | 11:49 AM
xshadow715's Avatar
my fuse box doesnt have numbers on it but both the audio and speaker fuses are working fine i swapped them and no change...
Old May 8, 2011 | 01:45 AM
xshadow715's Avatar
bump?!??! anyone? fml i just want this fixed =\
Old May 8, 2011 | 03:02 AM
DennisMik's Avatar
If the fuses are good, then check the red wire on the sub woofer. It is the battery voltage from the fuse. The black wire is ground. If you have voltage, then check the green with white stripe wire on the subwoofer. It is the turn on signal from the head unit; 0 volts when off, voltage when the head unit is on.
jskirwin
Jun 8, 2016 08:49 AM
Samedi
Aug 13, 2015 04:05 PM
starman9215
Aug 11, 2015 06:51 PM
papo99
Audio/Video/Electronics
Aug 9, 2015 12:55 PM
kirkhilles
Aug 8, 2015 10:53 AM
