Low beam works but not high beam?
Hi
I recently purchased a 2001 Maxima and have no high beam on the right side.
So I replaced the lightbulb with a Sylvania 9003/HB2 but the high beam still doesn't work.
Am I missing something?
If you have a model with DRLs, then it's your DRL module that got fried. Since the highbeam circuit runs through there, it affects the right highbeam. That happened to mine (twice), so I just completely rewired my highbeams to a separate relay/switch.
You could also try switching the L/R headlight relays...
This thread covers the DRL issue (which you aren't having) and does have some other info too.
http://forums.maxima.org/5th-generat...-your-drl.html
Ok, so let me jump in on this thread since it's rather recent...
I have 2001 20th AE, and this evening while I was driving, I noticed that the passenger side's low beam is out. I switched back and forth b/w low and high beams, and the high on this light still works just fine, it's just the low-beat that decided to die.
Is there a remedy for this as well? I don't have the DRL thing in my car. Is it just the bulb that's out, (which I kinda doubt) or something more serious?
Any help would be appreciated. Thank you.
jerrod99_se-l
Aug 27, 2015 08:27 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
YourLocalAsian
Aug 17, 2015 02:33 PM
MikesChevelle
Aug 6, 2015 11:36 AM
