rtp zinc drilled/slotted rotors shake when brake ....need help plzz
Old May 7, 2011 | 08:35 PM
blkbat_77's Avatar
hey guys,
i have a 2002 maxima and i recently jus purchased rtp zinc drilled/slotted rotors from a fellow org member from the nyc forums.
he said they were slightly used with under 10k on them....they came off a 5th gen but said it will work fine on mine....there is a little differnce in size but they bolted on
so i put new pads, got 3 new tires mount/balanced, (1 tire still needs to be changed) and got an alignemnt.....now when i drive over 35 and brake i feel a slight shake/vibration in the steering wheel and brake pedal....
pepboys supposedly checked them and said they arent wrapped, but im not for sure if they actually checked them....my question is do you think the rotors are wrapped? or do i need to give the pads some to form to the rotors since they're used??
thanks alot for any help
Old May 7, 2011 | 08:46 PM
NAVY00MAXIMA's Avatar
The holes where drilled are possibly not chamfered. I've heard the vibrations caused called shimmy-ing.
Old May 7, 2011 | 08:47 PM
How many miles do you have on your set of pads you are using?
Old May 7, 2011 | 10:31 PM
blkbat_77's Avatar
well i just went out and replaced them back to my stocks and no vibrations....i pmed the guy and hopefully hes understanding and will refund me my money
Old May 7, 2011 | 11:37 PM
altezzablazes's Avatar
warped rotors
Old May 8, 2011 | 07:06 AM
blkbat_77's Avatar
thanks guys im just waiting on his response
Old May 8, 2011 | 07:48 AM
CMax03's Avatar
WaRpEd.....Uprade to 6th front rotors and calipers and be done with all that 2000-03 warp prone rotors.......straight simple bolt-on!
Old May 8, 2011 | 04:10 PM
blkbat_77's Avatar
is that setup expensive? cuz i jus bought pads...and would i need to upgrade my calipers and bracket and all?
thanks
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
dshinn
Sep 26, 2015 08:07 PM
Socalstillen
Sep 26, 2015 12:01 PM
