Major Tune Up
Old May 11, 2011 | 03:13 AM
Noela's Avatar
Major Tune Up
Hello,
My car is about 140K miles now, and I am thinking of getting the tune up done. Since I've owned the car since it was about 10k miles, I am not sure the spark plugs has ever been changed.
What are some of the major things I need to consider? I am thinking of the following:
-- Spark plugs and wires
-- Power steering hose
-- Drive belts
-- Transmission fluid (did change it about 3 yrs ago -- still worth it?)
-- Shocks and struts
any others?
thanks very much - Noela
Old May 11, 2011 | 05:21 AM
Prophecy99's Avatar
check this http://forums.maxima.org/5th-generat...ml#post7983138
everything you listed is on par, you have studied well....and yes 3 yrs is a while for any fluid....change it
Old May 11, 2011 | 06:44 AM
Noela's Avatar
thanks - checked it out; what spark plugs would you recommend for regular driving - no autocross;
NGK Platinum: http://www.rockauto.com/catalog/moreinfo.php?pk=916818
NGK Iridium: http://www.rockauto.com/catalog/moreinfo.php?pk=393349
Also, do I need to change my valve cover?
cheers, Noela
Old May 11, 2011 | 09:50 AM
NmexMAX's Avatar
dot dot dot ...
cheers, Noela
Change your VC if it's leaking. But if you feel ambitious, might as well do it while you are doing the plugs.
Considering the price difference, I'd go with Ir's.
Old May 11, 2011 | 10:57 AM
kvk2003max's Avatar
cheers, Noela
Platinum Plugs
Add 6 to cart, Enter Coupon EMD5 to take 20 off. Total around $41 for 6 plugs. I got them for $36, but i can't find that coupon code. Good luck.
Edit: select store pickup to avoid shipping charges.
Old May 11, 2011 | 11:27 AM
pkrainert's Avatar
Also there are no plug wires, our cars use coil packs.
Old May 11, 2011 | 11:45 AM
Noela's Avatar
KVK,
Thanks very much.
I did order the NGK Iridiums from RockAuto for about $49, but decided to cancel it, and then order the NGK Laser Platinum ones from AdvancedAuto -- it all came to about $43 (tax inclusive).
I will pick up later tonight. Then once my drive belts arrive tomorrow, my mechanic will install the power steering hose, drive belts and spark plugs + oil change of course.
Thanks again for the tip.
Rgds, Noela
Originally Posted by kvk2003max
Platinum Plugs
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Socalstillen
Sep 26, 2015 12:01 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
ColdCananda
Sep 20, 2015 10:45 PM
