2000 Maxima SE Tire fitment.
Old Dec 24, 2001 | 09:23 PM
jwang03's Avatar
I have a quick question... I have a stock 00 Maxima SE with the sports package( 17" factory rim).
I'm in the process of needing to replace the stock tires that came with the car. I was thinking about fitting it with Kumho 235/45/17 tires. After doing some research, looks like the stock 17" wheel only fits tire that support 7" rim width... The Kumho 235/45/17 fits 8" rim width...
So I hope I'm not stuck with the only option of buying the OEM Brdigestone Potenza RE92 225/50/17 tire again. Any idea if the Kumho would fit? And anyone know any other good tire that will fit this factory 17" rim?
Thanks,
-Joe
Old Dec 24, 2001 | 11:44 PM
2001SE's Avatar
Michlen Pilot Sport A/S
Old Dec 25, 2001 | 06:25 AM
UMD_MaxSE's Avatar
Got Bent?
please check the sticky FAQ thread up top and try a search. THis has been discussed a lot. The stock rim is only 7" wide and tire manufacturers recommend no wider than a 225 tire on a 7" rim.
Old Dec 25, 2001 | 05:47 PM
Telus.net
Though I have Pilot Sport, not A/S, but I can gurantee you that Micheline has the best tire wear and life than any other perfomrnace tires. Although they are quite expensive, but you will have a tire that runs long life while still maintaining soft tread.
Old Dec 26, 2001 | 07:27 AM
doublea's Avatar
Re: 2000 Maxima SE Tire fitment.
Thanks,
-Joe
Hey Joe, I'm going to do the same change soon, buying 235/45/17 and I will fit those on stock Max 17" We had a long thread about this last summer, if we go by the book, I guess you dont do it, but I did the same with 98SE, installing 225-50-16 on the stock rim and it was the best ride I ever had on my 98. I suggest you try it and then if your not happy of the ride or if you dont feel safe buy a new set of 8" wheel.
Cheers
Double A
Old Dec 26, 2001 | 07:30 AM
Dario's Avatar
im running on Nitto NT450 225/45/ZR17
Old Dec 26, 2001 | 04:58 PM
C2MAX
i balanced my rims today, and i measured them at 8" wide? anyway... i am running a nitto n/t 555 245/45/zr17 on my stocks? i dont see a problem? the ride nice.
kjlouis
Nov 24, 2018 06:09 AM
MplsMadMan
Sep 4, 2015 02:23 PM
District
Aug 15, 2015 08:23 PM
jholley
Aug 11, 2015 09:38 AM
niZ
Aug 7, 2015 10:18 PM
