Pass Front Window Reverses Direction on close
Old May 21, 2011 | 11:21 AM
charlestek's Avatar
I have a 2003 GLE and when I shut my left front passenger window it goes up to the top then reverses direction and goes down automatically. There must be some type of limit switch problem . The only way I can close it is to carefully pull the window switch up in shot jabs.
Help!
Old May 21, 2011 | 12:08 PM
TallTom's Avatar
There is an easy 30 second fix for that. You need to reset the window.
Let me find the link.
Old May 21, 2011 | 12:09 PM
TallTom's Avatar
http://forums.maxima.org/5th-generat...t-02-03-a.html
Same thing, but with pretty pictures. Who doesn't like pictures.
http://forums.maxima.org/5th-generat...ction-fix.html
Old May 21, 2011 | 12:58 PM
charlestek's Avatar
Thank you still trying to see switch
Tall Tom,
Thanks. I found the other article but without the pictures.
I have the door open now, but still don't clearly see the switch.
Let me look some more.
Phil
Old May 21, 2011 | 01:17 PM
charlestek's Avatar
Can't see through vapor barrier
I hate to have to take the whole door panel off, but maybe I have to...
Old May 21, 2011 | 02:06 PM
TallTom's Avatar
I take it you didn't look at the links. You only need to pop out the small handle piece.
Old May 21, 2011 | 02:34 PM
charlestek's Avatar
Did look at links and pictures
Tom,
I did look at the links and read all 3 pages. Unfortunately the picture is misleading, or is hard to place looking at the vapor barrier. The switch is actually next the the "R" in "FR" on the vapor barrier, diagonally between the speaker and the inside door latch release. Looking at the picture, I thought it was below the door handle release, which it is not. I had to remove the whole inner panel to see it clearly. Fortunately, I did not crack anything removing the panel.
I got it reset, though I noted the motor does move the glass up slowly closing the window. I wonder if the rails need to be greased.
Old May 23, 2011 | 07:03 PM
cschmidt's Avatar
took a minute, but got it.
Just did this on my '03 I-35 (passenger side). The switch is lower and more forward than I thought from looking at the driver side pictures. A flashlight helped and feeling in by hand helped find it. Seems to be working ok on several auto up/down cycles today. Thanks for the links and recommendations.
Chuck
Old May 24, 2011 | 08:35 PM
olskool's Avatar
I have the same problem with my passenger window. Any suggestions on finding exactly where the reset switch is if the door is dynomatted?
Old May 24, 2011 | 08:38 PM
charlestek's Avatar
Draw a line between 2 o'clock on the door speaker and the door release latch
You will find the switch approximately in the middle of that line.
HOKUSMAX
Nov 13, 2017 04:34 AM
homeyclaus
Sep 3, 2015 06:15 PM
doctorpullit
Aug 20, 2015 05:15 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
KGMtech
Aug 18, 2015 09:21 AM
