Timing Chain Tensioner Question
Old May 28, 2011 | 01:18 PM
three.fiveSE's Avatar
I am working on replacing my waterpump, and currently I am at the stage where you need to put some slack in the timing chain. So far (with exception to close quarters) everything has gone fairly smooth , but I am having trouble getting some slack. I believe that I have released the plunger, but cannot seem to push the plunger back in. I took a picture (best i could)... any thoughts?
Old May 28, 2011 | 01:21 PM
sorry about the obnoxiously large photo
Old May 28, 2011 | 01:26 PM
P. Samson's Avatar
Rotate the crankshaft about 20 deg. backasswards.
Old May 28, 2011 | 01:28 PM
ok, i will try that, the service manual said to do that AFTER you pushed in the tensioner...
Old May 28, 2011 | 02:16 PM
well i just took the tensioner out completely, I should be able to replace the waterpump just fine now, but even with the tensioner out, i cannot get it to compress... bad tensioner?
Old May 28, 2011 | 07:40 PM
P. Samson's Avatar
I can't see your photos, but I doubt that the tensioner has an issue. Have you got the plunger stopper lever in the correct position? If you don't have it in the plunger "released" position you won't be able to push the plunger in. It'll only go in so far. There is a better drawing of this in the EM (Timing Chain) section of the FSM.
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
maxinout93
Oct 27, 2015 01:29 PM
max_speed97
Aug 26, 2015 07:46 PM
doobadoo
Aug 15, 2015 06:43 PM
ZerotoSixty
Aug 6, 2015 04:34 AM
