If I'm replacing the window motor do I need the regulator as well?
Old Jun 15, 2011 | 03:15 AM
Scott LaRock's Avatar
Spoke on this before, rear right window doesn't work, window went down, couldn't go back up.
Do I need to order both the motor and the regulator or can I get away with just the motor?
Old Jun 15, 2011 | 08:56 AM
schmellyfart's Avatar
You should be fine with just the motor. Though it wouldn't hurt to pull the door panel off and verify that the regulator cable is still tight.
Old Jun 15, 2011 | 09:16 AM
DavefromCA's Avatar
Yes, he is right. You should pull the door panel to verify wahts broken. How did you determine its the motor?
Old Jun 15, 2011 | 11:12 AM
I pulled it off yesterday, it looks fine but I don't know what the regulator is but the wires seem fine.
Old Jun 15, 2011 | 01:25 PM
Regulator:
Motor:
Motor installed in the regulator:
Old Jun 15, 2011 | 02:05 PM
Yeah I might need the regulator then lol.
Old Jun 15, 2011 | 02:08 PM
It has no power, went down but didn't go back up then it just went dead.
Also is the parts the same for the front and rear windows?
Old Jun 15, 2011 | 04:46 PM
TunerMaxima3000's Avatar
,,,, I have never seen a parts store that sells them individually. As far as I'm aware, it's just considered the same thing motor/regulator as an assembly.
If you guys can find the motor assembly separate, that's cool, how much are you saving though? Is it worth risking?
Old Jun 15, 2011 | 05:53 PM
Not really some dude here has a 02 and wants 30 for the motor and it's 50 new at rockauto so it doesn't make sense to buy such a old motor that could possibly die on me quickly. I just wanted to save a couple bucks.
Old Jun 15, 2011 | 06:30 PM
ahahaha then go buy the new one, silly question IMO.
Old Jun 19, 2011 | 11:35 AM
NHMAX603's Avatar
Window issue 95 se
i have an issue with my rear driver side window checked fuses tried new motor tried master switch tried rear switch tried ll the prats on the oposite side of the car nothing works i replaced all wiring into the door Team nissan wants 100$ just too look at it any ideas ? email me
billy.waitt@gmail.com
vingodine
45
May 21, 2016 12:46 PM
homeyclaus
Sep 3, 2015 06:15 PM
Shock_and_Awe
Aug 23, 2015 01:02 PM
Superbform
Aug 11, 2015 08:10 PM
kjm900r
Aug 5, 2015 07:14 AM
