"Service Engine Soon" light came on after intake install.
Old Dec 26, 2001 | 04:44 PM
BlackMax2k1's Avatar
During the intake install my friend unplugged the maf sensor before
I could say anything. The sensor is in there tight. I disconnected the battery overnight and it was fine in the morning when I started the car. Then in the afternoon I started the car and the light came on again. Any suggestions besides taking it to a dealer.
Old Dec 26, 2001 | 06:06 PM
UMD_MaxSE's Avatar
Got Bent?
Re: "Service Engine Soon" light came on after intake install.
messed up MAF? Can you read the code somehow?
Old Dec 26, 2001 | 06:10 PM
Cisco's Avatar
Re: Re: "Service Engine Soon" light came on after intake install.
Disconnect battery terminals for 1 hour, that worked for me.
GC
Old Dec 27, 2001 | 05:33 AM
Do you guys leave the air scoop on or off?
Old Dec 27, 2001 | 06:35 AM
UMD_MaxSE's Avatar
Got Bent?
doesnt matter.... the only sensor in the scoop is the temp sensor. Is that plugged in somewhere and plugged in tight?
Old Dec 27, 2001 | 07:38 AM
If it's not plugged in to the scoop then where would it
be plugged in?
Old Dec 27, 2001 | 09:15 AM
PCGuRu2K's Avatar
Thats about the only place it can plug into. Unless you have a cai... Other than that it can just be zip tied to the side somwhere if you plan on taking out the air scoop.. I would leave the air scoop though..
Old Dec 27, 2001 | 09:25 AM
Do you think taking that sensor and scoop out would cause the light to go on? And the only things holding the air scoop on are the two plastic screws on top? Is that ok?
Old Dec 27, 2001 | 11:20 AM
CIRCO's Avatar
The MAF must be messed up. I know when my intake slipped off while driving, the service engine light came on, but the car could not stay on for more than a few seconds, it would just die on me because of that sensor.
Old Dec 27, 2001 | 03:25 PM
The car runs great though. No problems with acceleration.
Old Dec 27, 2001 | 03:44 PM
CIRCO's Avatar
Re: Re: Re: "Service Engine Soon" light came on after intake install.
hmm... when your car stalls does it have a bogging sound?
Old Dec 27, 2001 | 03:49 PM
Re: Re: Re: Re: "Service Engine Soon" light came on after intake install.
It doesn't stall at all.
Old Dec 27, 2001 | 04:03 PM
CIRCO's Avatar
Re: Re: Re: Re: Re: "Service Engine Soon" light came on after intake install.
My bad I was thinking about another guy. You should just check the connections make sure the sensor is connected properly and try reseting your CPU. The service engine light in most cases has to do with sensors.
kjlouis
Nov 24, 2018 06:09 AM
vingodine
45
May 21, 2016 12:46 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
Flores94
Aug 11, 2015 12:53 PM
