Clunking when Turning
Recently, I've started getting a clunking when turning right with load.
If I'm letting the car take the turn in neutral or in gear with foot off pedal, everything is normal.
If I'm on the gas through a right turn that involves more than a 45 degree turn of the steering wheel, I SOMETIMES get a clunking noise.
When it happens, it doesn't only clunk once, it seems to keep clunking until I either get off the gas or straighten out the car.
Can anyone help me figure out what it is?
No, I'm not lowered at all.
I'm also suspecting the passenger side axle. It was recently replaced (less than a year ago) and so were the struts.
Stock Springs, KYB GR2 Struts.
Unfortunately, the axle is the advanceauto GSP brand. The thread about how they're crap seemed to pop up about a month after I had mine installed.
However, I don't experience any of the symptoms that people seem to complain about with these GSP axles going bad.
Anyone have an idea what's being affected here? If it's not hurting anything (doubtful), then I'd like to just leave it alone and just deal with the noise.
I had the same problem as well, but turns out that the bolts on the endlinks were loose. I would double check the torque on them. If not, I would follow this steps suggested by one of the member. "Stabilizer link, Sway bar bushing, Strut mount, Strut, Tie rod/ball joint (based on 3-9 or 6-12 tests), Motor Mounts"
I just did a fair piece of front end work, ES lower arm bushings, ES sway bar bushings, new outer tie rod ends, new ball joints. Result is much tighter steering, car used to float pretty bad above 100, hit 120 the other day on a straight and it was pretty darn solid.
BUT, driving to work the other day I did a rapid back and forth test, like a pretty fast wobble while driving about 70 and I got a hard knock on the driver's side. Sigh...here we go again.
I don't get this driving straight over ANY number of bumps, just in vigorous back and forth motion at high speeds. TBH, I doubt this would be replicated in normal driving, but I want to handle it.
So you guys are saying bad axles will do that? If AZ and Advance are crap, who makes good ones?
I had the same problem ( I think)
For me it was the end links. to test bounce the front of the car up and down as hard as you can to cause it to make the sound. For me bouncing the opposite side cause the noise. I had replaced my end links days earlier (if you didn't but had front end work done the mechanic may of removed them to gain access) The bolt hole on the control arm (where one end of the end link attaches) is a slot instead of a hole and the force of the wheel moving up and down while driving looses it (especially if you follow the haynes torque specifications). To fix, jack the control arm up with the wheel off to simulate the cars resting position and tighten the endlink bolt. The bolt should be a the bottom of the slot. Hope this helps.
tarun900
19
Dec 20, 2021 06:57 PM
Unclejunebug
Apr 2, 2016 05:42 AM
RealityCheck
Oct 2, 2015 06:34 PM
