Quote:
I did this mainly because I like the lip, like you. I also like the bumper lines.
I just want to see that car shine man, sorry to hate, but it's SOOO close to being a beauty, all you have to do is fix the fitment and it's on my fav 5th list. Think of it as negative reinforcemen
That's the same lip you have boss, my car is an '01. I swapped in the 5.5 lights and put a 5.5 grill into the '01 bumper.I did this mainly because I like the lip, like you. I also like the bumper lines.
I FEEL U positive criticism...but im am in the process of goin bak to the 03 bumper and stillen lip
and oem headlights
Quote:
Believe it or not, you and Tuner convinced me to keep mine in his grille thread. Gotta hold it downOriginally Posted by phatboislim
DAMN...no 5th gen front end love...i'm the last of a dying breed i guess.
(hope OP changes his mind lol
)Senior Member
ha, i wanted to change but seeing everybody switching to 02-03 bumpers reminded me of the integras where everybody was going from 90-91 to 92-93 and from 94-97 to 90-01...i'm sticking to my guns to make the 5th gen look appealing as/more than the 5.5
Quote:
The hole on the headlight bracket were u put the bolts thru maybe off, I would cut/grind out the hole a little bigger on the right side of the hole. So you could move the headlight in moreOriginally Posted by simpleNclean
fudge it imma keep it....i like your guys point....any suggestions on what i could do to make a beetter headlight fitment?
wen i totalled it i had to replace the radiator surpport bar maybe thats y its of...imma tek it to a body shop..how much u think they charge
i did the shop wanted 11,000 dollars to fix the car labor plus parts thats y it was totalled n i bought it back and fixed it unda a grand
Originally Posted by Nexus67
Believe it or not, you and Tuner convinced me to keep mine in his grille thread. Gotta hold it down(hope OP changes his mind lol
Quote:
Hellz yeah, 5th gen bumper and stillen lip FTW Originally Posted by phatboislim
If I had the stock 5th gen grill I would have kept it too, but I had no choice, and damn that bulgy and flashy SS grill! No offence Nexus
Quote:
^ Don't dothis, it's not your problem, your problem is a LOT more than just being out a little on a bolt hole.Originally Posted by Clashez
Did you replace the ENTIRE rad support? Like the upper, lower and everything? Or did you just replac the lower portion?
If you replace the whole thing, then you installed it incorrecly, or possibly there issomething jammed in between the mounting location on the Left side. I would recommed you pull it all apart and inspect it, the problem should be pretty obvious once you take it apart. You probably rushed it puting it back together and didn't notice something was wrong.
Besides, it only takes about 1/2 hour to pop the bumper off, maybe less becaus you've done it before.
Hey no offense taken lol. I painted the grille black awhile back (pics in album), it doesn't stand out nearly as much (hell, it almost looks like it isn't there in some of the picsOriginally Posted by TunerMaxima3000
)Quote:
I'm w/ you on that. I was ready to pull the trigger on a 5.5 front but then yours and Tuner's words jumped into my head lol.Originally Posted by phatboislim
Quote:
I got in an accident last October and some of the chassis was bent up by the headlight. I bent it back into shape as best I could but it stopped the headlight bulge I had. I would take both lights off and compare the two sides (to find any inconsistencies on the driver's side vs. the passenger side)Originally Posted by simpleNclean
Quote:
The flea bays anit that bad in black, if my car was an 00-01 i would get them in hid.Originally Posted by phatboislim
that joint is killer man..you make those ebay headlights sexy
Quote:
BTW, you don't need to put the [img] code around it twice.
i dont kno y it does that...it does that by itself....good looks thoughOriginally Posted by TunerMaxima3000
sick picture ^BTW, you don't need to put the [img] code around it twice.
Quote:
ayo...you retro fit or are those also ebay fog lights
YOUR taste....exactlyayo...you retro fit or are those also ebay fog lights
ebay.....but those are for now i should of brought everything back oem but its ok for the time being.......
Quote:
" -8.5" is wide enough.....for my taste!
Originally Posted by CMax03
IMO...Simply2much...8" -8.5" is wide enough.....for my taste!
ok buddy u could of just said it was 2 wide but u had 2 add simply2much thats wen u kno your a hater....its all good bro your were probally born in the 70's literally n e ways u stik with your 8's wide ill shyt on u n e day wit my 10.5's.....im just tired of sum of yall talkin smak could easily just say to wide or i dunt like but just got to add on.....
im in the scene of the art of wheel fitment cause i love the outcome.....try to get a 4.25 inch lip with your 8.5wide sikeeeeeeeeeeeee
I saw OP's car yesterday and have to say it looks great on the road. It's really an eye catcher in black. Him being very low makes it look even better. As much you guys want to rant, it takes a lot of work to pull this look off. I bet his cv axles hate him right now. We need some dam adjustable control arms.
Quote:
i'm actually saying that for the fact of saying...the ebay lights, for some reason, work on your car, i mean, seriously. the output might suck, but the ebay look, just worksOriginally Posted by simpleNclean
Quote:
i lulz'dOriginally Posted by nishfish871
Quote:
The output on the ebay reflectors is a lot better than on the ebay projectors. But his car def makes them work. Those being modeled after the 5.5 lights I think would look better, but I agree w/ you his current setup still works.Originally Posted by phatboislim
Quote:
it sucks we cant camber our rears.smh
Originally Posted by BLACKKILA.GTR
how much rubbing in the bak?it sucks we cant camber our rears.smh
wen i was at the wheel shop they put the rims n tires on n i pulled out n the car was too low n grazing on the wheels(madd smokkeeeee) but wen i got home i raised the bak so it wasnt grazing no more....but it only grazes wen u hit a hard enuff bump and going over potholes and in the driveway just got to kno how to angle the car.....i might b the first maxima to camber my rear...its not easy very time consuming....you have to place a shim behind the hub.....
Quote:
thanks broOriginally Posted by Nexus67
Man that last close-up pic is TOUGH. OP that should def be your sig (reduced size tho lol but still)
your car is ready bro the body is fuking clean just got 2 step it up bro your max has more potential then mines
I was simply being sarcastic with you.....I'm not hating on you....it's your ride you can mount pavement rollers on your car.....It's yours! They're just too wide for my taste......That's as simple as I can put it! Oh yeah< I wasn't born in the 70's......Originally Posted by simpleNclean
ebay.....but those are for now i should of brought everything back oem but its ok for the time being.......ok buddy u could of just said it was 2 wide but u had 2 add simply2much thats wen u kno your a hater....its all good bro your were probally born in the 70's literally n e ways u stik with your 8's wide ill shyt on u n e day wit my 10.5's.....im just tired of sum of yall talkin smak could easily just say to wide or i dunt like but just got to add on.....
Ok so i'm going with the xxr 521's 18x10's +25 all around what tire size should i run. I'm only going to be dropped like 2'' Sprint spring and not getting coilovers til next summer. So i don't want a crazy streach... so what are my options
so i am a new maxima owner.. and i am into the stance/stretch/poke scene so how do i camber my maxima front?? wat offset you running??
Quote:
u could go with 235/35 or 235/40 or 245/40Originally Posted by Clashez
Quote:
2.5 degrees in the front im only running negative camber for fitment purposeOriginally Posted by 1clean2kmaxi
dont do it
Quote:
+1 Originally Posted by simpleNclean
check out tyrestretch.com they have pics of tire sizes on different rim width sizes just enter the what tire and rim specs you want to get an idea of how stretched the tire will be
NOTE: some tire brands run wider and some narrower FYI
Yo man it looks clean no matter what they say. They ain't seen it in person like I have so they just going on assumptions.
I got them D2's in the other day so I'm bout to drop it finally!!
Yeah I know them headlights are bi*ch to install to get flushed in there. U saw how mine were. I still got to get the HIDs in mine lol
And I need that front lip!!!!! Haha
I wouldn't want to roll around in that thing where i live due to all the potholes and crap, Even me being on eibachs is pusing it but i gotta say that's one of the meanest looking maxima's i have ever seen, Nice work man keep it up.I have a brand new set of nexen n3000's 235-40-18 on g35 wheels,I know im only on eibachs but what offset would you suggest to get somewhat like the 10 350z's with that flush front and a nice poke in the rear ??
Quote:
what do you mean by the 10 350'z? but something like 9 or 9.5 will be nice in the front and the rears 10 wide with a +25Originally Posted by 036mtmax
you dont have an option on what offset to get for the '10 '350z' (370z) wheels...the offsets are what they are....but to make those 370z wheels look proper, you HAVE to be lower than eibachs..no way around it. just learn to drive slower and dodge potholes.
[/IMG]
